new lift and some parts installed. pics
kolelt
Over the weekend me and my friend put in my new lift. Superflex with 5100 in the back with stainless steel brake line with ss extended bump stops. In front it's tundra 5100 on 2nd perch with eibachs with new stainless steel brake lines. New fat bobs diff drop. New brake pads and rotors. Two new axles, new power steering fluid, new front diff fluid and new brake fluid. I have also done to the truck before this, new rear and transfercase fluids, tune up from plugs to belts to new water pump new valve cover , jdm engine less then 100k.
Looks great! I just put the bilstein 5100 in the rear of my 3rd gen too and love it so far. Great looking rig, keep it up!
you need to weld your pan hard bar bracket if you haven't already.
EDIT: saw your cross bar, it was hidden from all that sexy black end! looks good.
Yea me and my friend made a cross bar from the panhard to the frame cross bar. We drilled little hole in it and stuck a nut from inside and bolted the custom cross bar from the panhard. You think that's enough ?
I thing that bar you made will be feeling a lot of shear on corners. Keep an eye on it over a few hundred miles that the hold does not get wallered out from movement. The bar will fail before the grade 8 bolt will
I drove to my shop 3 miles decently slow with my pan hard detached so I could weld it up and it drove fine. I think you should be good.
Next week or so I will be cutting the sliders of and welding back plates on the frame so I can my friend weld the panhard and the cross bar ? The bar is L shaped about 3/16 thick.
emilygrace28
