New Lift/Tires finally!
Yeah, for now I have the stock tire underneath - but I need to find a better solution for the long run.
I have spoken to Armorology about fabbing me a rear bumper/tire carrier. This is probably the way I am going to go... but I don't know how to get around the giant bumper of the 4runner.
I am still trying to picture how to fab one up that will look good. Lances is great, but it involved a bit more work/cutting than I am comfortable with.
-Mike
First Outing
By the way... got to take her out for the first time - met up with the FJ Cruiser Trail Team
More pictures (probably too many) at mikemillar.smugmug.com
The suspension was amazing off road!
-Mike
Wow the Coopers look really agressive. Very cool.
I expect them to be loud on the highway, how are they?
It also seems to have a wide footprint. I got Revos and they seem to have a smaller "foot print" It has a concave design by where the sidewall meets the tread.
Then again, yours are MT and the Revos are AT.
Either way, your 4runner looks really tough. :rocker:
I went and saw your other pics.
Did you get that awesome bumper?
If yes, who makes it, where did you buy it, how much?
Sorry about the questions. lol
The Coopers are definately much louder than stock tires... but I don't know how they compare with other MTs. I got used to it fast... but I am definately aware of the rolling resistance with these agressive tires, in that the truck slows much faster when coasting than it did with stock tires. Acceleration is still very nice.
The bumper is the new creation of Shrockworks - I just photoshopped it onto my truck, but if you want one check out the threads at Toyota120.com
I am sticking with my stock bumper for now, but eventually will either get an ARB or the Shrockworks (I want to see them both in person) also I want to figure out a rear bumper solution at some point and want them to match up.
I'll post some trimming pictures ASAP.
-Mike
Wow! You had me fooled. :D I thought they were real.
I heard ARB is supposed to come out with a new bumper also.
Maybe I could follow you to one of your off-road ventures, if you don't mind? Never been to one in CA
That looks really good.........I would just lose the dealer tag on the front.....unless they are paying you for the advertising......lol
K6UK said:
Well,
Finally my lift is completed!
It's now got Donahoes up front, Bilstien 7100s in the rear, with custom Deaver coils 20% firmer than stock and 2.5" longer. A 4 crawler 1" body lift, and some 285 Cooper STTs on Lexus GX470 rims with Spidertrax 1.25" spacers installed.
She rides great on road - now to get her off into the desert!
-Mike
What are the Spidertrax 1.25" spacers for?
Spidertrax
Here's a pic of the spacers:
media.nl
Their job is to space the wheels out 1.25" - otherwise the tires will rub on the A-Arms in the front. This could also be accomplished by using a wheel with the right backspacing - but I had my heart set on the Lexus OEM wheels
-Mike
Curious about the wheels.
Don't the Lexus wheels have the same center cap design/shape as the Toyotas?
I noticed that you had the Lexus wheel cap... Was it because the Toyotas didn't fit?
btw, I'm definitely getting the spidertrax spacers, but they are out of stock! I know that with bigger tires such us ours need fender trimming, but I'm sure the rubbing areas will change with the wheel spacers. Where did you do the trimming? Did you "have" to remove the mud flaps?
With the stock setting, I have to trim around the front triagular piece. I haven't cut mine yet, because the rubbing wasn't too bad. I might as well wait for the wheel spacers before I start trimming.
Thanks for the info.
I haven't had a chance to experiment with different wheel caps. I think there is a Tundra wheel that uses the same cap, but I haven't tried to find one yet. The caps off of my 18" wheels were WAY to small - and the wrong color.
The wheel spacers really doesn't help on the fender rubbing... but if you're hitting the A-Arms then they move the tires out and away.
The front mudflaps definately had to go - there is very little space between the tire and the body mount (to the rear of the wheel well) at full lock. If I agressively accelerate, or hit a bump at full lock I do rub a little on this mount.
The rear mudflap probably could have stuck around, but I would need to shave down the fasteners. I don't want any parts ripping off my truck - I rather remove them myself. :)
The trimming in the front was mostly the black fender liner, but also involved a slight amount of trimming at the edge of the fender (silver part on my truck).
I know people are a little shy about doing cutting - but I figure it's just the price of doing business and you might as well just do it.
You might as well wait for the spacers before you cut, because the areas you rub may very well change with the spacers.
-Mike
Functionally, the 4runner is just fine. I'm just doing it for a wider stance. Might help compensate for the height increase and provide stability for the gained top-heaviness.
What do you think?
K6UK said:
...The wheel spacers really doesn't help on the fender rubbing... but if you're hitting the A-Arms then they move the tires out and away.
-Mike
Could you post some images of places you cut?
The wider stance won't hurt you any in that department - my truck feels pretty solid and I'm sure the spacers helped in that area.
Yes, I'll take some pictures of the trimming and post them up!
-Mike
Aren't you going to have problems with your tires hitting the fender lips if the wheels are pushed out 1.5" and under full compression - eg when off-roading?
When I re-read your suspension setup (including body lift), maybe you have enough room even under full compression.
I was concerned about that when I was setting it up, and that is what prompted me to go with a small body-lift. I didn't run into any problems my first time out - but I have by no means flexed every which way. I'm trying to get out to Hollister Hills on the 11th which should give me some better impressions.
So far though, I have run into no problems.
-Mike
K6UK said:
Thanks everyone... yes I can't wait to take this out, I'll try to join you on your next trip.
As for where the work was done - everything was done by Demello Offroad.
-Mike
Do you mind me asking how much you paid for the whole thing?
Demello supplied the parts too?
Thanks.
Well... to be quite honest I never really totalled the whole thing up... and I'm not sure I want to :)
Denial is way more fun.
I'll try to gain the courage...
-Mike
Just wanted to say your 4Runner is one of the best looking 06s I've seen so far. If I had more time and money to hit the trails and put the truck to the test, I'd run a similar setup to yours. As it stands, though, I've got the XREAS and am limited to a few inches. Oh well... nice truck!
Kaliram
