New Shocks, Struts with Lift?
Granzyman
I have a 98' and have put on a 3" Revtec and put on some monroe front struts. It has been over a year and it seems to ride still little rough up front. Any suggestions? Also i have factory rear shocks and was thinking of replacing them. First off, good idea? and do i need stock shocks or should i get longer ones, and if so which ones? Any info i can get i would greatly appreciate.
thanks
Have you tried using the search feature on this forum? There is a ton of info already out there that may help you decide. :)
Spacer lifts like the one you have are well known for stiffening the ride, its just a characteristic they have. The only aftermarket shocks that I have experience with for the 4Runner are Old Man Emu. If you want to keep the spacers in then perhaps you could try the OME comfort struts up front (part number N91SC), these are valved for a softer ride. They are a full inch longer than stock when extended. I would get new rears at the same time. You could try OME N86C (comfort) or OME N86 (firmer). These are also slightly longer and will probably suit you better than stock shocks as they are less likely to bottom out and damage the shock at full extension.
Clocktower07
