New Sonoran Steel Product: KDSS High Articulation/Long Travel Trac/PanHard bar
[MENTION=1795]sschaefer3[/MENTION]
How does this product differ from the panhard correction kits (PCK (Panhard Correction Kits) – eimkeith.com) or a rear swaybar drop kit (KDSS Rear Sway Bar Drop Kit for 5th Gen Toyota 4Runner/Lexus GX (2010-
– Blackgate Customs
If essentially the travel is only limited by the contact between panhard bar and kdss piston, what differs between the option you provide and others out there?
I understand that there is an increase in travel w/ the radflo shock, but taking that out of the equation, and maintaining a off the shelf shock.
The Trac/PanHard bar does not hit anything. The U shaped brackets that hold the sway bar hit the Trac/Panhard bar.
Raising a mounting point or lowering the actual mounting of the bar does not change the fact that the U shaped brackets holding the sway bar hit the trac/panhard bar.
We had to move the axle side inward one full inch to over come obstacle one. No bracket or spacer is going to overcome that very first obstacle. The obstacle 2 is the passenger side. Where everyone get the first impact that they notice.
High Articulation KDSS Trac/PanHard Bar 2010+ 4Runner with KDSS - $395.00 : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
In 2012 we bought a brand New Trail 4Runner with KDSS. While the bulk of or work at that time was with 3rd gen 4Runners (1996-2002), I knew this was one heck of a truck and spent years dreaming up parts to make it better. After installing our current offering and other manufactures suspension offering for these trucks, there was one thing that I felt everyone dropped the ball on.
The Trac/PanHard bar for the KDSS trucks. We all know that the Jeep Wrangler and the American full size pickups with straight front axles had Trac/PanHard bends in them to dodge around things for many years. These bars are all sand cast and difficult to manufacture on small scale, which the KDSS market it.
After working on this for literally years we found a solution. The original prototype was fabricated out of cut tube and zigzagged all over the place. It was incredibly time consuming to make and frankly looked ugly. But at that point we had a pattern that cleared everything. Full stuff with coils and shocks removed and full drop with shock removed. We now knew exactly how far the KDSS bar would let the suspension move, uninhibited bay the trac bar.
So finally how do we actually make this thing? Waterjet is how. Starting with a 3 foot by 3.5" of Cold Rolled Solid Steel Bar, the Waterjet carves this bar out of solid 1" thick cold rolled steel! The entire bar is a consistent 1" x 1" solid cold rolled steel. It is heavy. On the 4th gen 4Runner, Toyota used 1" round solid hot rolled round stock. So this is not a new idea with the size and material used in this application. The ends are custom polyurethane bushings made for us by Daystar in Phoenix. They have grease grooves and we have made several improvements to the mold over the last 8 years (2010-2018) as we have always made a straight tube Trac/PanHard bar for the 4th/5th Gen 4Runners and the FJC. The adjustable end is a huge 7/8"-16 grade 8 threaded rod into a tube adapter made by Ballistic Fab in Tucson, hollow end of the bar is 1.5" x 1.5" x .120 wall Cold Rolled Square Tube, finally the same bushing setup as the other end.
The bar will run rear shocks 1.5" longer extended than anything currently offered off the shelf for a 5th gen 4Runner. We are going to work on that with Radflo.
any black friday savings or discount codes available for this?
also, i don't foresee it but i thought i'd i ask, is there a possibility of running into issues when running the radflo shocks in the rear and icon in the front? Valving or dampening issue?
Radflo will have a Black Friday sale, the extent of that is not yet known. The bundles with Radflo shocks will all get that discount, but I have not decided on the single bar.
You can run what ever brand of front coil overs you want. They just need to be the same 2.5 size. Well that is suggested, for the best ride.
PM sent I have a nice used bar available.
I'm ready to pull the trigger on the bundle w/ the custom radflo shocks and the trac bar!
lmk!!
lindwlson982
