New suspension coming soon! Anything else i should replace?
So i think i have settled on the toytec lift with 906 out back! Stoked! But is there other shiznat thats easy to replace while doing the lift?.... Sway bar bushings, bump stops, tie rods, UCA bushings? I dont mind upgrading stock parts even if they r not worn out so that i dont have to get back in there. Just looking to create a great ride! Opinions? thanks for any help.
Summits
Summits
Buncha stuff..... you could do the tundra brake upgrade (that should be your #1), replace all ball joints and TRE's, sway bar bushings if you want. You wouldn't need to replace bump stops with 906's... you could replace CV's if you feel the need. Install a diff drop as well.
If you have the cash I would overhaul the entire front end anyways. That means Lower Ball Joints, Inner Tie Rod Ends, Outer Tie Rod Ends, sway bar bushings, and steering rack bushings. No need for UCA bushings as they typically don't go bad as quickly and if you're going to remove the UCA's you might as well just get aftermarket UCA's. Bumpstops aren't needed for just 906's as you won't be lifted that high.
which one?
Summits
Just planning ahead on a lift later,which toytec lift did you get?pardon i'm a noob with 3rd gens.:biggrin2:
premiumusedautoparts
