new tire question
T-Love
hey jus wondering if anyone could give me specifics on wat type/size lift i need to put 255/75/17 BFG Mud-Terrains on my stock 05 V6 2wd
Welcome!
Maybe no lift would be required. It's that close to fitting as is. A 1"-2" lift on the front will ensure cool looks and a good fit. The 255's without wheelspacers will fit well and look good. Because they are not super wide there's minimal trimming (if any) required to clear when the wheel is cut and the suspension moves.
While not specific to you 2wd this site will show the areas and a fix for the most lkely rubbing point. http://www.top4runners.com/ja/2007/wheelspacers.html
:cheers:
thanks for sharing, im not very familiar with the whole suspension/tire thing so i do appreciate ur response
Cool... The tires will fit easier without wheelspacers. When you look into lifts you're looking for 1-2" of net lift. The way the geometry of the suspension works if you add a 1/2" spacer that'll yield about 1" of lift. If you use a spacer that measures 1" it'll yield about 2" of lift.
There's many manufacturers of the lifts. The advertising literature varies a little bit; some advertise the spacer thickness others advertise the net lift.
There's literally hundreds of posts discussing the different lift options. Daystar, Cornfed and others all get the job done. Read some, search some and have fun! Search this way, it works better than the search button... http://www.toyota-4runner.org/showthread.php?s=&threadid=43046
:cheers:
one more thing... will the fact that the 255 size tire is 10mm narrower than the original compromise the use of my current rims?
No. Your stock rims will be fine.
peacefulpiranha
