Hi guys,
I just got a cheap second hand 2nd gen '91 4runner SR5 Limited and it's got a few probs that I would like to fix up or diagnose. If you have experience with this model and could help me, i'd much appreciate it.
GEARBOX:
Firstly I have some pretty noisy gearbox whine. When I'm idling it has a small whine when clutch is engaged. If I clutch in, it disappears. That leads me to believe it is probably the thrust bearing. When I take off in first, it's noisy, all the way through to 4th gear where is it quiet and doesn't whine at all. Then in 5th the whine is back but not as bad. The whine is also only present when the accelerator is on and transferring power into the box. I thought that since it's quiet in 4th, it may not be the thrust bearing. Could it be an input shaft bearing? Either way, I'm going to change the gearbox oil and put some of that PTFE additive in it. So can anyone pinpoint a possible problem area with these symptoms? I'm not that well versed in this type of transmission and even reading the service repair manuals don't help much.
ENGINE:
It's seeping some oil from the sump gasket and also somewhere higher up on the back. Not sure if it's the rear main seal or the valve cover gaskets. I put some stop leak in there and hopefully within a couple of hundred km's, it stops leaking. Also the lifters are a bit noisy all the time, especially on start up. Am i right in saying these are hydraulic lifters? Would you recommend a thicker oil? Maybe they are a bit gummed up. There is some gunky residue built up inside the oil cap, so maybe the engine needs an oil flush additive and then oil change?
WIPERS:
The wipers were working fine in the rain a few days ago, then suddenly one day the fuse blew and they stopped mid screen. I pulled into a servo and replaced the fuse. It started again but was going very slowly and wouldn't change between speeds or intermittent. Also, the rear wiper wouldn't work. Then the fuse blew again. Now I just have to replace the fuse and it will blow without me even touching the wiper stalk. So I'm thinking it's the combination switch, as the power for the wipers goes directly through this, and it's the common link between the front and rear wipers, right? These models don't have a body control module do they? I don't think it's the motor, because it did seem to go, just not change speed. So I might try changing the combination switch, but if anyone has any other suggestions, let me know.
PASSENGER ELECTRIC WINDOW:
When I first got the car, the front passenger window wouldn't go down with the switch on the passenger door. Only would go down on the switch of the drivers door. Now it doesn't go down at all. For a while, if you flicked the passenger and drivers door switches at the same time, you could coax it down. I'm convinced it's not the regulator because when it moved, it moved fine. I'm guessing it's the drivers door switch panel? Also, the power mirrors don't move. I got one to move briefly, but I think that switch is also gone. Does anyone have any other ideas?
Any help would be much appreciated! Thanks a lot
GEARBOX:
ENGINE:
WIPERS:
