Newb question about correct Spark Plugs
jetdrivr
Sorry...this may be a lame question but I am new to this vehicle so here goes.
I just bought a set of NGK BKR5E-11 Spark Plugs for my '02 Limited off the internet. My question is this... the hood on my runner states that I should only use "Twin Ground Electrode Plugs" (in fact they even have a picture with the correct type circled and the single type with an X thru it!) but the replacement NGK's I just purchased are "Single Ground". I thought I was buying the correct thing...they were direct replacements listed for my truck!?!
So...Am I ok to install these NGK's that were listed as compatible for my '02 Limited 4wd or should I send them back and replace them with the "Twin Ground" type?
Any advice???
As long as you use a good plug lke NGK you should be okay. Honestly most dual electrode plugs out there are kinda crappy. I am NOT a fan of Bosch and they make the +2, +4 electrodes. I tried to get NGK Platinims but can't find them around here. I ended up putting a set of Splitfire Platinum. When I changed mine they had some crappy Autolites. I reccomend NGK, or Denso.
ordered
Placed the order for the correct plugs and they are being shipped this week...thanks to everyone for your help and advice.
Bringing this thread back from the dead - I bought some Splitfire V Power plugs to replace the Denso k20hru11 ones that were in the truck when we bought it.
Basically they are one electrode with a split end, which was the closest thing autozone had in stock to a dual electrode. (They don't carry NGK or Denso, and were out of the Bosch variety). After installing them, the engine seems to be knocking or a least a little louder, rpm dependent. If it doesn't quiet down within a couple days I'll probably pull them out and buy some NGKs.
Has anyone had good or bad experience with the Splitfire V Powers in a 4Runner?
Thanks in advance.
I don't seem to have a good idle and bad gas mileage. I have already done a fuel injection cleaning and a intake cleaning along with the throttle body. I am going to find out what kind of NGK or Denso that it takes and order them. Either that or I will just get the from the dealer. $3 something a piece isn't bad.
brendaglores
