Newbie - How to change a front running light blub
esaboopa
How does one change a front running light bulb, I have a burned out driver side running light bulb which I would like to replace. This is on an 2003 4runner. Does anyone have an URL that might be helpful.
Thanks in advanced
Im not sure about a URL but you shouldnt need one, there really easy to change. Just get on your back under the front bumper, give the connector a turn and wiggle it out of the housing. Replace the bulb, put it back in the housing and turn it the opposite way. Its the exact same concept as replacing a headlight or fog light.
just go to your local auto parts store with the burnt out bulb and you should see them. they come in a box of two. be careful though because there is a similar pair where the number is slightly different. if you have trouble finding them just ask the person working their and they will get it for you. and changing the bulb is easy, like any other bulb on the truck.
Secret is do it from underneath...can't get to it on top. And the bulbs only go in one way...make sure that they are seated all the way in or else they fall out...
goddesszilla
