NEWBIE question: Engine breaking?
So on top of the 4runner having some level of "smart system" not letting you downshift when it's problematic, I assume I can also shift right back into D at ANY point, and it will then return to adjusting the gear when appropriate?
That is correct. Shifting back into D will just remove the gear limiter. So far example, when Im driving up hill, i like to put it into 4th at keep it at around 60mph. Once I finish cresting the hill, I shift it back into D and it will automatically shift up into 5th.
The wear and tear on an automatic transmission, fluid, etc. is mostly during shifts, not when it is in a particular gear. Once it is in a gear, the transmission doesn't care which way the load is applied. The only difference in coasting in 5th vs 4th or 3rd is how fast it is spinning and some increased load on the gears. It's not like the gears are strong in one direction and weak in the other. It's just the opposite side of the gear teeth get the load during coasting vs. accelerating.
Wait so instead of flicking it up twice from 3 to get to 5, i just have to hold it??? I have just been swinging it back to Drive and then left again if I wanted to go into S4 lol
Yes, I learned this from another post. I was doing it the dumb way for a long time.
When driving down steep hills I use the brakes to slow down to near the speed I need to be at, then downshift to brush off the remainder of the speed and hold it there. Then minimal additional braking needed to maintain the slower speed.
Transmission braking consistently around town at stop lights is nuts.
So yesterday I was able to try out engine braking for the first real time - I was coming down a local mountain road (paved), and in D it was just accelerating. Even when I went into S it was the same... I believe I eventually tried going to S-2 but at that point the RPM went up above 4.5k and I didn't keep it there, went to D and used brakes but I smelled some burning smell?
I feel like my first trial of this concept didn't go so well...
Going into S just drops you to 4th gear. 4.5k RPM isnt that bad. Burning smell ...new car right? It'll go away ahah. Make sure you're using BOTH the brakes and engine braking. I can take a video of me engine braking down a LONG steep mountain road and show you the transmission temperatures (pan and converter).
An excerpt from this trucker website, primarily for big rig drivers, but applicable to all heavy vehicles like the 4Runner. I bolded some of the text:
Safety Tips for Driving on Hills | fleetanswers.com
Tips for Approaching Hills
The approach is often where accidents and mistakes happen, because driver's expect problems when coming down the hill, not coming up. Keep these tips in mind:
* Watch for signage - Hills with hazards, like falling rocks or deceptive grades, will have signage that indicate their characteristics. When approaching a hill, watch for this type of signage, and heed it.
* Slow down - Do not speed up to try to get up the hill. Slow down, especially as you approach the top of the hill. Towards the top, the contour of the road will make it difficult to see, so going too quickly will make risks even more hazardous.
* Prepare for surprises - As you approach a hill, know that you are going to face surprises. Start being more aware, so any animal, vehicle, or road obstruction doesn't turn into a catastrophe.
* Note the weather - Wet or icy roads can make it more challenging to get up the hill, so note the weather as you approach.
* Prepare for less visibility - The surprising risk of hills is the fact that you can't see what's coming. Be prepared for limited visibility as you approach the crest.
* Yield to downhill travelers - If on a narrow road or other situation where someone must yield to oncoming traffic, always yield to the downhill vehicle, which will have trouble stopping.
Tips for the Descent
When you descend the hill, you need some additional tips. Consider these:
* Slow down - The hill will cause some natural speed increases, so slow down to avoid speeding too quickly. Also, it's difficult to stop on a hill, so a slower speed is wise.
* Downshift - Running at a lower gear will help hold you back so you don't get going too fast. This will also help reduce wear and tear on your breaks.
Use brakes wisely - Use brakes wisely to maintain a safe speed, but avoid situations where you need to stop suddenly on a hill, if possible.”
Oh I was definitely trying to avoid using the brake pedal. So I guess switching into a lower gear AND selectively applying brakes simply means that you won't have to run your brakes like you otherwise would have to in automatic?
Cause that likely changes things :)
And yeah, new car. About 700km
Talyn
