Newest member of the 35" club
diponyou
My 33s werent in the greatest shape and I found these for a great deal so I said why not.
hancook dynapro mt 315/75r16
Currently it is just a suspension lift and it does rub here and there :wacko:
Coming up next is a 1.5" or 2" bodylift as well as some hammering.
Do you plan on regearing?
Welcome to the Tempe 35's club. I'll see you around
I'm sure we'll cross paths at some point. If you ever want to take your rig out to bulldog canyon or somewhere let me know. I go out with a few montero guys who go out frequently.
I actually just saw a green 3rd gen with a lift, 33s and roof rack drive past me a few minutes ago. An older dude with a big beard.
How much suspension lift do you have in the front? Looks massive for not having a body lift.
It does look awesome though! If it were me, I would just cut more and forget the body lift nonsense :thumb:
5100s on the second notch from bottom
Eibach coils
I'm probably going to put the perch back on bottom one once I go with the body lift.
I just removed the bottom half of the front bumper so that gave me tons of clearance.
Bot?
you should consider a tapered body lift. basically you have the front at 2 inches and the rear at zero and make each puck in between increase in size. then put your springs on the first perch. now you have 5" of lift all around. the body lift doesnt really help in the rear because the tires stuff in at an angle and rub the vertical wall of the wheel well.
