Arcking
I'm having trouble with the brakes on my '87 pickup - not a 4Runner, but I believe it has a similar brake system. The brake pedal goes ALL the way to the floor, with very little resistance. After rigorous pumping of the pedal, some resistance can be felt, but the truck still doesn't slow noticeably.
When bleeding the front brakes, only fluid exits (no air). I haven't been able to bleed the back left brake due to a rusted bleed screw, but the back right brake seems to endlessly bleed a substantial amount of air. I have not been able to bleed the LSPV due to an issue with the bolt for allows for bleeding. You can feel all four brakes working to some extent when the truck is up on jack stands. As another note, after pumping the brakes the fluid in the reserve appears aerated.
Does anyone have any ideas as to the cause? Why do the front brakes not provide any stopping force? Is there a chance that this is due to not being able to bleed the back left or LSPV? Could the LSPV be bad? Any chance there'd be a hole in the line (return line) that wouldn't be leaking?
