No heat and code 25
johnnyd2723
Good Morning. Not so good for me though! I started the trusty 4runner this morning and she was running rough and sputtering. I let her run for about 10 minutes as I always do when its bitter cold out and thought maybe I had some condensation in the fuel tank since it was only 9 degrees out and tank was about 1/4 full. So I got in to go up to gas station and it was freezing inside, never warmed up and blowing ice cold air. I filled her up and put some dry gas in then decided I better turn around and go home. I continued to let her idle at home and noticed there was no pressure in the upper radiator hose but running at normal temp. She never did blow any hot air and then finally the check engine light came on, code 25.
A little back story with this too. Last Friday it was 60 degrees then the storm moved in rain then ice and it dropped to 25 by 1:00. I was at work and everyone was leaving early due to the ice so I started her to melt the build up of ice. I noticed when I started it she sounded like she was missing at the tailpipe but when I went to leave it was smooth again. Drove it Saturday no issues. Drove it yesterday no issues until my last stop. Went in to the grocery store, came out started her and she was sputtering. Now this morning.
Any thoughts what this could be? Coolant is good. Thanks for your help
DJNutshell
