cj80cruiser
Senior Member
Those gauges aren't accurate and are slow to move with temp. You'd have to get a scan gauge or ultraguage to know for sure.
Bringing back an old thread. [MENTION=102606]infamousRNR[/MENTION] and I recently made a video on addressing higher than normal coolant temps. Hope it helps people diagnose why they're running a little hot. Enjoy the show!
Great video. Any thought to draining a little more coolant out by opening the drain on the block? When I did a drain & fill I had a decent amount come out after draining the radiator.
http://www.toyota-4runner.org/3rd-g...lock-coolant-drain-plug-97-v6.html#post747328
I've never bothered worrying about what's left in the block. You get most of it out by just draining the radiator, which is around 2 gallons.
Well just for a visual, this is what I got out of the block into a 1 gallon jug after draining the radiator. I know it's not much but if you're one who suffers from Obsessive Compulsive Disorder then it would be on your mind.:
Im about to swap over to a 170* thermostat and new radiator. Im usually at 195-197. I see 200 in city traffic on hot days. Try adding a bottle of redline water wetter, supposed to help with temps.
https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8183
What about a 160* ?
Would you recommend for a SC application?
What about a 160* ?
Over the last week, I took my '01 in for several things (dealer), one of which was to have them let me know if a running temp of 204 degrees was excessive. They said it was. They then replaced my t'stat (installed in 2014), replaced the radiator cap because they said it was cracked and charged be $202.
After taking possession, I rechecked (via OBD2 Fusion) and it was running 204 degrees. I took it back, another mechanic confirmed 204 was "perfect" and they refunded my $$.
When I asked them about where they positioned the "jiggle valve" they told me it made no difference and was....."not a factor in controlling the operating temp of the engine".
I am not sure what to do at this point.
just check the thermostat yourself..its only 2 bolts to pop off to get to the stat and flip it to the 6 o clock position
i was running the same temps as you intill i fliped my t stat and now im at a cool 190
