jgue467
Senior Member
Frame swap on a taco vid: https://autoweek.com/article/recalls/toyota-frame-settlement-could-cost-company-34-billion
:cowboy:
:cowboy:
I read some of the responses from people complaining that time expired for their claim to have Toyota replace the frames. But, is their anger misplaced? Isn't this more a result of the areas of the country that decide to use salt to de-ice the roads than a problem with the way Toyota built and rust-proofed the frames? What about all the other components, fasteners, and body parts that get rusted to shit from the corrosive salting of the roads. Is Toyota responsible for that as well? Shouldn't their anger be directed to the people who've made the decision to use salt instead of other non-corrosive options?
Here's an interesting article to read:https://www.bridgestonetire.com/tread-and-trend/tire-talk/pros-and-cons-of-using-road-salt-in-winter
The bottom line, de-icing the road saves lives and salt is cheap so it will continue to be used for a long long time.
It really makes me glad I live in an area of the country that has mild winters and therefore no need to salt the roads. Some of the nicest classic cars come from California because they're not rusted to shit from the road salt.
The thing is though, the Toyotas seem to be a lot more prone to it than other makes.
Well, you guys make some good points. But, all I know is a Toyota frame will pretty last forever in the California Bay Area because of the fact there isn't corrosive road-salting going on. I guess Toyota could have done a better job protecting the frames from corrosion but the real problem lies in the salting of the roads. Every vehicle I've owned, including my two 3rd Gens were/are essentially 95% rust free because of the lack of road-salting.
But, what about my other question? Should Toyota also be responsible for all the rusted body parts, suspension components, fasteners, etc because those get rusted to shit as well for the road-salting? I've seen the pics and videos of 3rd Gen owners from the rust belts of the country. Their entire undercarriages are covered in rust. People remark all the time on our YouTube channel how amazingly non-rusty our California rigs are.
I'm not sure if this is true across the board. In general I think the 3rd gens have held up pretty well. We have a lot of 3rd gens on the road here. You do not see very many Nissans, or Broncos or Blazers from that era that are in any better shape. I think the Toyotas are as good as any others and it comes down to care and attention on the owners part.
Surface rust is one thing, but seeing a rear control arm mount completely rotted off the frame rail is another.
Not that it NEVER happens with other makes, but like I said, it seems to be prevalent with Toyotas.
After you've done it a few times though i'm sure it gets easy. Looks like he got that whole swap done in less than 2 days.
The salt is only part of the problem. These frames were not properly coated to begin with and Toyota admitted that with this recall. Had they been properly coated, they would still rust, just not nearly as quickly. When I bought my 2016 4R brand new, I started taking matters into my own hands right away. 3 coats of paint on the whole frame and all suspension components, paint inside the frame as best as possible, fully undercoated frame and floors. Lubed the spare tire winch which I do twice a year. I paint the under side of the truck 2-3 times a year to cover everything that I can't coat with undercoating. I also plan to spray oil inside the frame rails using a weed killer spray bottle and allow it to run out for a couple days before driving the truck. With all this, if the frame still rots, I say Toyota is at fault for sure lol.
I'm going to respectfully disagree with you. The SALT is the main problem and why these frames are rusting. It's a simple cause and effect. Like I said, without the salt, these Toyota frames would essentially last forever.
I'm guessing the cost for Toyota to better treat the frames to prevent them from rusting due to the policy of salting the roads is more than it is to settle the claims from customers.
Your 2016 4runner just lives in the wrong area of the country. The California Bay Area has one the least affordable housing markets in the world but at least our vehicles don't rust to shit. So, we can safely live in our 4runners without worrying about the frame disintegrating out from under us.
Will mine rot out and be part of the pending 5th gen frame recall despite my best efforts? Maybe, but at least I can say I tried.
I think if you paint it well and then apply fluid film regularly and inspect it, it should last in the salt states. The problem is with people who never look down there. Once the rust starts it has no more protection and just keeps going.
I've seen way too many jeep TJ's with frames rotting away far worse then a 4runner around here, and those TJ's are generally newer. It's scary to look at a used TJ and see these hoakie frame "repair" caps that slip over the rotted out sections then get tack welded to any remaining frame rail.
I know that around Maryland, the state highway dept will use a pre-treatment of magnesium-chloride which is supposed to help keep the asphalt from freezing so that the road salt will work better. The chemical is literally destroying the concrete bridge abutments and speeding up the corrosion on the rebar in the concrete and structural steel, no less how it's destroying anything aluminum on a car. I can't blame all of the frame rust issues on that one chemical, but it sure isn't helping any vehicle have a long life span around here.
