NZ 4Runner
chch4runner
Meet my SR5 22r 4Runner.
I bought it early 2014, it is my second 4Runner.
I had a 1992 2.8 deisel SR for 10 great years and after 100,000km sold it at 300000 km as I wanted an 80 series Landcruiser which was vey nice, but too expensive to run - should have kept the 4Runner.
My parents bought it in 1990 when they were first introduced in NZ, the local dealer was really keen to sell it as it was the first on sold in our town.
My Dad bought this one and a freind of his bought a V6 when they arrived not too long after.
Dad kept it for about 240,000km with the Toyota dealer servicing it, he then sold it to my brother who used it as a horse float tow vehicle and farm hack, so when I got it about 8 years later it was very tired and filthy.
So over the last 2 years and 25000km this is what ive done.
After a week of evenings cleaning inside and out the car was fairly presentable but running badly.
The original Toyota washable air filter was thrown out probably 200,000km late and replaced with a standard filter, now she could breathe and the difference was noticable, new plug leads, cap, rotor and a nervous morning swapping the plugs later ( they hadnt been changed for years and were very hard to remove, lots of crc and turning them a bit then back again to clear the threads worked) and she was starting to run well.
New shocks were vital as the originals were still there and well past their best, I bought a set of online autoparts in Australia which was much cheaper than buying in NZ.
The diff had a whine so that was rebuilt with the Lsd tightened up for better traction.
The front seats were worn out, so I got a set of front seats from an SSR-X, much more comfortable with sheepskin covers.
I failed an inspection due to a hole in the muffler so a nice big free flowing muffler and removal of the catalyst made it better, I need to replace the rear pipe with something larger as it now whistles under hard acceleration.
The transfer box was whining like crazy so after putting free wheel hubs to carry on driving it for a while I put in another box.
Ive been chasing a number of vibrations so after rear wheel balancing, new driveshaft UJs, driveshaft balance, gearbox mount tonight I fitted new rear springs and the vibration is gone, it was so nice to drive without the feeling that the driveshaft wanted to tear something off.
Ive been driving this car since I was 19 ( now 45) and its nice to have Dads old car and keep improving it.
Ill have this one for years.
Martin
Kiwi 4Runner
I was thinking today about other modifications I have done on the 4Runner.
When it was a few years old I put Hella semi sealed headlights in it with 100/90 bulbs which improved the ligjt output as the original ones were hopeless.
Jump forward 20+ years and I decided that the lights were still hopeless, a bit of googling pointed to the wiring loom being a bit light for the job.
After looking at building a loom I found one on ebay for $45 US complete, I had to re solder a couple of joints but its worked fine so far and the headlights are much improved.
Kiwi 4Runner
Beautiful 4Runner! Welcome to the forum.
...Hella semi sealed headlights in it with 100/90 bulbs ...
After looking at building a loom I found one on ebay for $45 US complete, I had to re solder a couple of joints but its worked fine so far and the headlights are much improved...
Those 100/90 watt bulbs are hard on the headlight dimmer-combo switch. You said you had to re-solder... Did you rewire so the power to the filament would not go through the dimmer-combo switch anymore, or
did you buy the H4 conversion harness with the relays, or
did you just upgrade wire size?
I bought an h4 coversion harness from Thailand I think
A couple of the connectors weren't well crimped so I soldered them.
The original hi/ lo beam switch coped for 20 years so I did ok!
We dont have headlight dimming in NZ, just off/low beam / high beam is it for daytime running lights?
Kiwi 4Runner
This weekend was oil and filter change time, nothing special in that, but it reminded me - does anyone have any clever ways to stop oil running down the block and over everything when taking the filter off a 22r? I always put rags there but they never seem to catch it all.
Kiwi 4Runner
A couple of weeks ago I put new springs in the back to get the wagon back to level, result is reduced vibration and much better ride as the springs are stiffer than standard but not too harsh, it is nice not to have loads of body roll.
I nearly traded it in on a 97 Prado SWB until i was looking on youtube at a video of a SWB, the access to the rear seats is not good enough to use it as a family vehicle especially as my son is 6' tall and still growing.
Pity though as it was low milage, tidy and had a 1KZ-TE 3L turbo diesel would be a bit of power upgrade from the 22R.
I was feeling a bit sentimental about trading it, but was looking forward to a new toy and more power.
Martin
Kiwi 4Runner
So I bought the 3rd gen which is stunning to drive, but I wasnt impressed with the headlights so the 100/90s and the plug in headlight loom out got robbed from the 2nd gen, so it now has 60/55s which arent so bright, but probably more in keeping with the loom and switch gear, and probably about the same output as the 100/90s before I put the loom in.
Im still having odd vibrations at above 80km/h so im going to try another drive shaft. One thing I have noticed is the spline on my driveshaft has marks that look like it has been chattering so im wondering if that is stopping it sliding smoothly when under load. There is also more vibration when im in 5th which im hopjng doesnt mean the gearbox is about to fail!
My son is learning to drive shortly and will be using the 2ng gen which is kind of cool as he will be the 3rd generation to drive it
Kiwi 4Runner
I had a look in the 3rd gen folder, but at the moment mine is being treated very nicely with no modifications so im not looking again in case I get too many ideas! but the 2nd gen is going to be played with more now it isnt my Dd, having said that I want to keep it fairly original and not spend too many $$$!
Kiwi 4Runner
Today I decided to sell the 2nd gen.
The dog and I took it for a good run in the country on Saturday afternoon, then I took the 3rd gen out to my brothers place about 40 mins out of town that evening, I have a sentimental attachment to the old car but logic says im not going to use it as the 3rd gen is so much nicer in every way.
So this weekend provided the autumn weather stays dry Ill start polishing it up ready to sell.
Sent from my SGP611 using Tapatalk
AndiGarage
