O/D light flashing
vtferret
So I took a look at a 1990 4runner yesterday. 3.0 v6, automatic four speed. 200,000 miles. Beautiful under the hood, and no rust on the frame.
The only aesthetic issues I noticed were that the front bumper had a dent in it, it is missing the fender flare on the driver side, the paint on the hood had a bit of oxidization, and the top layer of glass on the sun roof is cracked (doesn't leak though).
So, naturally I took her for a test drive. The first thing I noticed was that the the gas pedal response to get it moving was a lot more than I'm used to on my 2002. I thought it was a "old throttle cable" issue, but I had to get the engine up to nearly 1500rpm to get it to even start rolling.
Once moving I didn't notice issues with the driving, it seemed to accelerate fine, the brakes were a little spongy, but that could easily be a fluid issue, and it still stopped in a safe enough distance that I felt comfortable.
But then I noticed that the "O/D light off" was blinking. I hit the O/D button, and it stayed on solid, hit it again and it kept blinking.
I checked out the yota forum, and there was a thread about how some guy was having the same issues, and all it ended up being was a solenoid.
(Overdrive light flashing on and off. - YotaTech Forums)
I don't have a code checker, and I didn't think to ask if the dealer I was buying it from had one.
So, here's the point to my post here.
1) Does it sound like it would be a solenoid issue?
2) If it is a solenoid issue, will I need to drop the transmission to swap parts?
3) Does it sound like the vehicle is worth 1350 (1850 after tax and tags).
Thank you!
A flashing OD light means the transmission is throwing a code. It's probably a solenoid, because that transmission doesn't know much else, but read this: Toyota 4Runner O/D Off Light Flashing
I think the check engine light is supposed to come on when the OD light flashes? If it didn't, be sure and see that it lights up for a second when you start the truck. If it doesn't, the bulb is out (possibly on purpose), and you should require the seller to fix that so you can pull the engine codes.
