OBD scanner is not communicating with truck
LV2001BI
Hi this my first thread post, realize that there are numerous posting on ODB scanners but I have spend the past 2 days reading historical posting on this subject didn't get far, found a thread from 2011 but it ended and never really got resolved. So I'm hoping this community with its collective knowledge can help this newbie before Ii got stark raving mad.
Last week I purchased a Foseal wifi OBD 2 reader & Dash Command app it didn't work just gave me goofy data, like rpm swinging from 500 to 5500 at idle & vehicle speed was 65-90 mph parked, no coolant temp or any other data also couldn't pull any emission codes or find message that states no codes stored.
So I tried the free app ODB Auto Doctor that at least gave me coolant, rpm air intake temp & it showed no emission codes stored, but the ODB wifi reader kept kicking out of the wifi network had to constantly connect, it also kicked me out of wifi when i toggled from 1 screen to another. I think i got a used reader because when i opened the box the tape that should be on the pin connectors was balled up & shoved in the pins. I ended up sending it back to amazon for a refund. I then bought a LELink blue tooth reader & purchased the EngineLink app. I received the new reader this afternoon the blue tooth worked & easily connected to my iPad air with the app open prior to connecting the adapter. Now the issue is it get no data & when I try to read any stored codes I get "Error busy try again later". it maddening, so I tried this reader on my wife's 2006 avalon and it worked like champ it immediately connected via blue tooth and it gave me speed, engine rpm, tongue, fuel level, power coolant temp, I was also able to see what PIDs were available so I was able to customize a few pages. So I know the app & blue tooth scanner works which makes me wonder if my OBD port works. The weird thing is I see the red light when the adapter is connected & once it links to blue tooth the green flashing is present. So there is power to the port, I checked the 7.5 amp fuse in the engine bay its ok so I'm left scratching my head.
Again this is a plea for help.
I don't have a solution necessarily for you, but I tried a similar app to my car stero (IdataLink) and couldn't get it to work. Even though I can get information from it from ScanGauge II, Hand Held ODB2 reader and having no issues, I found out that the person who did the coding for the app did not put all the 'hand shakes' for communicating. With how old our vehicles are, I have a feeling this is a large part of the problem. Did you talk or find ANY information that someone else HAS used this on our vehicles?
What I would sugest is take a hand held ODB2 reader and plug it in. See if it takes it and gives you the codes, if it doesn't than its a bigger issue.
This is pretty much what I had to do in regards to make sure mine was working and not disconnected/fuse blown, or what not. I haven't ran into a ODB2 port that has been faulty honestly as that would lead to a lot of potentially other issues.
With Engine Link, what Adapter IP Address and Port Number are you using?
I use Engine Link on my iPhone 5 with out any real issue. I have noticed that I have to restart my phone from time to time because Engine Link will fail to reconnect sometimes.
Brand of reader
Hi what brand & model reader are you using also is it wifi or blue tooth?
If it helps...quoted from JamesD on a thread I'd made some years back for my 96. Of course it won't help at all if a bluetooth issue.
The only 4 pins on the OBD 2 connector is 2,4,5 and 16.
2 is White and that is the serial data line
4 is White/Black is ground
5 is Brown/Red and that is ground
16 is Violet and that is fused 7.5 amp 12 volts
In my case it was pin 5 that was open. It would work with a friend's reader but not the state's.
H.Sikina
