OBDII PC Interface
greasefingers
I did not want to hijack a thread I previously asked a question about, so I started this one. It has remotely been discussed before. So is anyone using an ODBII device? I am only interested in a blackbox to Laptop scanner connectivity. I want to monitor Air flow, air to fuel ratios, read trouble codes, clear codes, hydrocarbons, O2 sensor performance, and plot certain parameters. Some even simulate a Dyno. This would be nice so I could actually debunk or validate any bolt-on performance Mod.
About a year ago I purchased an OBDII scanner from http://obddiagnostics.com/order.html
(See my reply in the 87 octane thread for more details)
It's a blackbox to laptop type system, but I'm not sure it does everything you mentioned. For example I don't think you'll get dyno simulations and hydrocarbon emission data. It does monitor and log around a dozen or so parameters like throttle position, RPM, ignition timing, O2 sensor info etc. It reads fault codes and is supposed to be able to clear "check engine" lights.
Deno91
