I did the HCF delete, but I have yet to notice a bit of difference in get up and go or fuel economy.
There is no doubt that the filter is restrictive, but I think the gains may be so minimal I'm not noticing them. *shrug*
I'm with the same agreement as you! I believe it's due to the large surface area of the filter it allows much more air to be brought in versus if we had a smaller filter just allowed just enough air in.
btw at highway speed (60mph) I was hitting 23-34 mpg?!?!! Is this even possible?
we can all agree that the hydrocarbon filter is restrictive to some degree (maybe insignificant but maybe not). we can all agree that because of the restriction there is a pressure drop across the filter. any pressure drops in the intake system means less air molecules into the combustion chamber during the intake stroke which means less power. so most people figure that by reducing the pressure drop in an intake (such as by removing the hydrocarbon filter) that you would in turn gain fuel economy (maybe an insignificant amount or maybe significant).
this idea is completely wrong. remember, the engine power and the amount of fuel that is combusted is regulated by the throttle / butterfly valve. the throttle intentionally creates a pressure drop. so any reduction in pressure drop through the intake system caused by removing the hydrocarbon filter would mean that your right foot would simply be slightly less on the gas pedal for any particular speed. the free-er flowing the intake, the more closed the throttle will be. there is no impact to gas mileage.
After doing this I can't notice any difference in power and I have yet to see any change in fuel economy even closely tracking it via my ScanGaugeII on the same highway at the same speeds under the same conditions.
Often times, K&N filters are way over-oiled. This can cause an oily film to build up on the MAF sensor which can affect its readings, causing it to miscalculate AF ratio. In some cases, the damage to the MAF is permanent (or the damage caused by careless cleaning). Now, this may not be your issue at all, but it's something to look at.So last week I had my oil changed and air filter checked, and was told I needed a new air filter. I decided to put a drop in K &N filter in rather than the OEM paper filter. I was told that by removing the HCF filter, I would gain a little more flow as well. So I went ahead and did this, and since then, my gas mileage (according to the onboard computer) has gone WAY down. I would consistently get 17-18 around town and 22-23 on the highway (with 32.8"tires and a 3" lift). Now the on-board comp is reading 12.5-12.9. No matter how aggressive I drove before that, I never saw my computer below 16.8. What do you guys recommend? Should I try resetting the ECU? I can't imagine how removing the HCF and adding a new K &N would cause this.
Thanks.
Also consider if you may have used fuel from a different brand or station than usual.
If all else fails, you could throw a paper filter back in and see if it really makes a difference.
I would agree with this....if the oil builds up on the sensor it can cause this. Removing the HCF filter will make oil build up easier too. Get some MAF cleaner from your local auto parts store. It is really easy...just don't directly touch the wires. They are protected by a plastic housing so it isn't too big a deal...just be aware of it.
When I switched to the K&N filter (still have the HCF in place) my mpg went up by about 0.3-.4mpg...not much but every little bit helps with a trail rig.
