Weekend Update 255,102
Replaced the water pump, it was leaking from the bottom gasket seal - that was the source of the coolant leak (as I originally expected)
I used Asin water pump PN WPT-100 which came in my ebay Aircabinman kit, but can also be purchased from Amazon as a kit with the pump gasket, and the thermostat gasket:
https://a.co/d/fNLtO9Y
Followed Timmy and Sean's
videos for the most part, so I won't post all the steps and pics (I barely took pics as I went) but I will list what I did differently, some of which was inspired by
Part 2 of the video
Disassembly
Pretty straight forward, but when I got to removing the timing cover #3, top, the belt looked great so I decided to reuse it, along with the rollers
I also checked the tensioner and tensioner roller, no oil seepage and spun/looked really good, so I reused both of those, too.
Deviating from Tim's video, I removed the tensioner with two 12mm sockets, leaving the AC compressor and bracket installed, just like he did):
- a 3/8" short 12mm on a 6" Snap-On wobble extension (vs the universal and tape) on the rear bolt, with another 6" extension below it
- here is a 10" Dewalt wobble on Amazon: https://a.co/d/5haJIDY as an example
- a 1/4" short 12mm socket and ratchet on front bolt.
I opened the tensioner bolts evenly front and back until the tensioner dropped out. I used a ball joint press to reset the tensioner and held it in place with a small jeweler's screwdriver that fit the hole, barely protruding from the rear hole of the tensioner.
Reassembly
I made a check list of all parts and torque specs and crossed them off as I went along.
I cleaned chased all the threads with wire brushes and this kit from Amazon:
https://a.co/d/90PAZgp
Cleaned everything else as best as I could with degreaser, brake cleaner, and lots of shop towels. Then oiled all the surfaces with Marvel Mystery Oil.
I spent extra time cleaning the gasket surface for the water pump, razor blades to get all the old material off, then steel wool, then paper towels and inspected with finger and optics (magnifier and zooming into camera pics)
I noticed some mild pitting on the gasket sealing surface of the block after cleaning the snot out of it so I decided to use FIPG like Timmy did in Part 2 video. Applied a thin bead on the block side of the metal-shim gasket, installed it, then the pump. Torqued to 168 inch pounds in 3 steps in a criss cross pattern, including the thermostat housing studs. Let that cure an hour, then installed the thermostat and housing and checked/retorqued all to spec.
When it came time to install the belt, I did what every one does except I installed the actual tensioner last. I was super careful with the tensioner roller threads since aluminum, those were good, thankfully, and torqued it down carefully. The belt slid back on with minor effort.
Installed the tensioner, pulled the pin, and ran it around a few times to check timing, all dead nut.
To make the AC belt easy, I removed the AC idler roller (I was planning on replacing it, but it too was good) the belt installed easily and I was able to drop the roller in, torque it and tighten the belt. The other belts were done first no issue.
Before I refilled coolant I gave started the car and let it run for a few seconds, sounded same as before. Yay! Filled with coolant and let it sit overnight (about 24 hours, actually) for the FIPG to fully cure, then burped it and drove it the next day. All good.
Why did the water pump gasket fail?
I can only speculate, but here is what I observed:
1. Gates brand pump with a sealant channel was used (the pump is still good, actually - I did not reuse it)
2. A paper gasket was used
3. Black RTV (or FIPG) was used on the pump side
4. Gasket surface on the block was not clean, I scraped off more than 1 gasket
5. Gasket surface on the block had mild pitting
I suspect that the bolts were not torqued to spec, and in time the paper gasket saturated with coolant which lead to the failure.
I will check the belt at 307K miles, and if it still looks good, might run it another 25K and check again. Next time I go in I will replace everything including the crank and cam seals.
