OEM Auxiliary Switch??
Mick1
Is there a good Auxiliary Switch available to fill the empty factory switch position between the Wiper Heater and 400W Inverter switches?
I am looking at fitting two of the OTRTTW (3) position assemblies for lights, but will need another switch to control a Diamond K9000 up/down antenna motor.
The Duct tape covered Cardboard panels are sized to represent the (3) position OTRTTW switch panels.
:wtf: Well I can't believe that none of you are interested in something that looks stock to fill the two empty switch blanks we have.
I just ordered a couple different versions of these to see if I can make them work.
I ordered a 58328-47 SPST On-Off Rocker Switch Pilot lightes Green / Amber. Hopefully I could use this one to activate the switch panel of OTRTTW switches.
And the second switch I ordered was a 58027-11-BP DPDT Mom On-Off-Mom On Rocker Switch. I am thinking I can use this one to control a Diamond Motorized antenna mount.
I moved one of the top two oem switches down with the other two and put OTRTTW switches up top and a 3 pos. OTRTTW switch panel down below. The toggle switch is the kill switch for my LED's with another foot operated switch on the dead pedal for when I'm using them. I'm thinking of switching the 3 bottom ones to the newer lower profile covers from OTRTTW or similar though as I've hit my knee on the lower ones a couple of times.
Picture003-14.jpg~original
Really slick harper thanks.
I now have also moved my stock switch with the other stock ones. Just took a little shaving with a razor blade to fit it.
Now I have two blank plugs to mess with in the future.
