OEM Looking 5th Gen NAV Info Thread
This is the Holy Grail for me, but I want to do it with an iPad like these guys do:
iPad mini - Toyota 4Runner ? iPad Car Mounts and Installation
It's on the 2015 to do list...
I have not seen an ipad installs yet that worked well with the audio in the vehicle. And as far as I know, there is nobody that can make the ipad sync with the OEM sound and steering wheel controls. Also, you have to activate the ipad manually (the swipe) and even the hands free calling you have to manually activate (siri).
However, one day someone will figure all this out and I for one would love to have an ipad as my head unit.
You're right. But head unit replacement might be close with CarPlay. I don't think Toyota has officially announced their support yet. Until then, I'll use the iPad (or Nexus 7) as a supplement to the head unit for maps and music.
I think I have figured out how to get my USB back..
And... The NAV has quit working ( it works, it just will not find a satellite).
Waiting to hear back from the manufacture on this little snafu
Did you get the USB back?
Was your SatNav fixed?
NAV is working now, however, I have not been able to get my USB to work properly. I order a new cable and I will mess with it when I get back from Colorado at the end of the month.
Astrium GEE-1102
I just purchased one of these Astrium GEE-1102 for my 2011 4runner, thanks for your input on the install. I haven't installed yet but you information is a great help. Did you find out if one of the three unhooked wires go to the USB ?
I have a question too! Did the unit come with a wire harness for other things, such as RCA outputs? Wondering if this would be a good alternative to a standard double-din unit with dashkit.
Cost really isn't that far off from a higher-end Pioneer nav unit, as they are listing for $900-$1400 on amazon, and suggested retail is topping upwards of $1600 for the top-of-the-line units.
Also, doesn't the sharkfin antenna have GPS built-in, or did Toyota use different models (or wiring harnesses) for certain models?
Thanks!
EDIT:
Never mind, just checked your link to the unit, it actually has RCA outputs for 4 channels plus sub! And 45Wx4 should be plenty enough for the stock speakers (for a while!), so I may just get this one in a bit!
Nav System
I installed the unit in about two hours taking my time, everything works. I would like to get the 90010-26010 knobs. I checked at my dealer and they wanted 30.00 dollars for them and had to order not in stock. Where did the guy on here get the TR4 Knobs ?
Any updates? Looking at purchasing the same one on ebay.
So far it has been better than the OEM NAV on my TE. It's dead... Does nothing, radio from time to time.
Sadly, I tried several mods (USB jack mod from Tacoma world) and nothing has worked. I gave up on it. Nothing will work with an iPhone on this unit via USB.
$30. Full retail is under $5. Sorry I saw this too late to help.
Thank you, for some reason I had not seen the activity on this thread.
[MENTION=64685]TOY2G[/MENTION] Do you know what the purple jumper is for on the lower half of your 1st post, 5th pic (next to the cooling fan)?|I'm trying to figure out a way to switch from N.A. FM bands to Euro FM bands (i.e. from 'odd' ending channels to 'even' ones like 88.8) and wondering if that is the conversion switch?
Thanks!
NAV system upgrade
The GPS antenna was the easy part. ...
All things said and done.... Yea I would do it again. Here is why:
Pros.
-it's affordable
-it is truly plug and play (about an hour install)
-the Quality and fit is high
-user interface is pretty simple
-the software used has been used for many years
-it looks nicer (IMO)
-you keep steering wheel control
-it sounds great
-you gain two inputs (AUX & Micro SD)
Cons.
-you loose party mode
-you loose your USB outlet (the unit comes with one)
-you loose voice command
-you cannot play DVDs on the main screen
-the knobs do not match the HVAC
-the phone and NAV volume is not as loud as the music
Nice install guide. I admire you for trying this upgrade. What I don't understand is that you have a 2010 TEP "with NAV and KDSS". Why do this to upgrade the NAV system?
I just ordered a 2015 TE with Entune Audio but without the NAV. I figure that if I ever want the NAV I can get a Garmin or other brand, stand-alone NAV system and put it on a stand in the car. Several threads have said that the Toyota T4R NAv is hamstrung and outdated compared to current offerings (maybe this answers my 1st question). The only advantage I see to this kind of upgrade is having the system on the in-dash screen, which is good. You've also got a new radio, audio amplifier and CD player. But is it worth $900 compared to a $300 Garmin, etc?
This install is in my 2013 SR5. My 2010 TE already has NAV, but even so I still have Garmin 3497 both. ONLY because the OEM Toyota NAV don't work (input) when I'm moving and the aftermarket NAV unit we put in the SR5 just is not good as the Garmin.
Thanks!
It looks to just be a fused or a diode of some sort. But I really don't know.
TOYO4G - thank you for the writeup. I was looking lately for something simple to install in place of stock radio in my 2012 T4R (SR5 4x4 with no bells and whistles) mostly to add a backup camera and DVD but without loosing vital functionality (BT phone and streaming, steering wheel controls). I found this unit on Amazon for $749 (actually two versions that looks identical but having different part numbers: GEE1715S and LXM17T4RU15). Your Ebay source in Canada has GEE-1715S for few bucks more, but has more reliable info than the guy on Amazon. It is very hard to find any info about these units so your posts are very valuable, especially that they are real user experience, not marketing BS.
Did you instal the backup camera? Any input on that (what kind, where, how did you guide wires?). I installed aftermarket radio in my 95 Tacoma and my biggest complain is a booting time. How this one goes? For example how long does it take from starting the engine till you see the image from the backup camera? In Tacoma it takes 7 seconds from starting the engine to see the backup camera footage. It seems like forever.
I am not a big fan of in-dash Nav systems as they seems to be always outdated - I found Google maps with Nav on Android phone to work the best for me. I don't care about XM radio too - I let the free trial expire and never turned it on after that. Mostly I'm "reading" books wile driving, streaming internet radio over the phone or simple have my own MP3 commercial free music. Voice dialing never worked for me - for example when I dial number "Seven" the radio says "Canceled". :barf:
But the biggest selling points are hands-free phone, BT Audio integration, MP3 on USB or CD and of course backup camera. Everything is included in my basic stock unit except the backup camera. I tried to go with "rear-view mirror" route, but it is more work than it's worth (and the price of good mirror is almost half of this unit). So now I'm thinking of getting this unit for my "Bismarck".
The USB plugs (OEM) no longer work. I assume it's one of the three discount tend wires. The unit did come with a plug in USB adapter, and it has 5 matching color wires to the small whit plug that I left unused. I suspect I will be able to simply wire that USB cable back into my stock plugs (when I install the backup camera ( on order)
Have you figured out the USB? I look at the wiring diagram and the blue plug is not shown there. Maybe it goes to XM radio which is not shown on the wiring diagram.
However the diagram shows USB to be connected to something called Multimedia Interface ECU. This unit is connected to the radio with one of the white plugs you did not use (the one with 12 contacts). The other white plug you did not connect (the one with 8 contacts) seems to be connected to the stock microphone that is placed in the roof console.
Maybe it is possible to trace wires going out of the glow compartment USB. USB needs 4 wires (+5V, GND, Data+ and Data-). From the wiring diagram it looks like it is a flat brown 4connectors plug where 1=GND, 2=Data+, 3=Data-, 4=+5V. If the other end of this USB cable (where this brown plug goes into Multimedia Interface ECU) is somewhere close to the radio make a cross-over to new radio standard USB.
EDIT:
Actually Multimedia Interface ECU is on the right side behind passenger kick panel so it would require about 3 to 4 ft custom extension to connect the brown plug with USB in new radio. But it is doable.
Astrium GEE-1715
I have a 2011 Toyota 4runner.I have had this radio for about 6 months. I love the radio. I went to install the TPMS and could not get it to work. Any one have this radio that has had luck with installing the optional TPMS ?
Tire Pressure Monitor System....on the radio? I'm lost?:shrug:
seltzernator
