OEM Part Numbers for 3rd Gen 4Runner: Tie Rods, Ball Joints, and Wheel Bearings
JWaldz
Moderator
Anything I've missed, feel free to let me know. I'll steadily update this post. If any part numbers have been updated feel free to post them and I will update them here.
A couple notes: I used ToyotaPartsZone because their listings are easy to follow and link. Other sites like Camelback Toyota probably have better prices but are harder to link to one individual part. Also, in the compatibility lists you might not see your vehicle in the list immediately. You must click "See All Vehicles" to expand the listing.
Driver (Left) Side
  • UBJ: 43310-39016 (Same for both sides)
  • LBJ: 43340-39465
  • ITR: 45503-39075 (Same for both sides)
  • OTR: 45047-39215
Passenger (Right) Side
  • LBJ: 43330-39585
  • OTR: 45046-39335
Front Wheel Bearing Part #'s (Non side specific)
  • Wheel Bearing: 90369-54002 (Old # 90369-54001 - Don't Buy)
  • Inner Oil Seal: 90312-95001
  • Outer Oil Seal: 90316-69001
  • Snap Ring: 90521-99114
  • Spacer: 43524-35010 (chances are you wont use this, but it's good to have on hand!)
  • Skid Control Rotor: 43515-35010 (chances are you wont use this, but it's good to have on hand!)
Rear Wheel Bearing Part #'s (Non side specific)
  • Wheel Bearing: 90363-40020-77
  • Type S Oil Seal (Inner/Axle): 90310-50006
  • Type K Oil Seal (Outer/Shaft): 90313-48001
  • O-Ring: 90301-88077
  • Retainer: 42423-20010
  • Skid Control Rotor: 43517-35010
  • Snap Ring: 90520-36045
Other Miscellaneous Corresponding Parts
  • UBJ Snap Ring: 90520-39180 (Same for both sides)
  • UBJ Wire: 90580-10001 (Same for both sides)
  • UBJ Dust Cap: 43324-39015 (Same for both sides)
  • LBJ Flanged Bolts: 90080-10066 (Need 4/side)
  • Steering Rack Boots: 45535-35030 (Same for both ends)
  • OTR Jam Nut: 90170-20003
Informational/Replacement Threads
Instructional Videos
Awesome! Yeah, it's very convenient to have all this info in one spot. I'll being doing huge maintenance/build in July...this'll make it easier. Thanks!
Also:
Steering rack boots (x2): 45535-35030
LBJ bolts w/ washers (x4 per side): 90119-10933
Axle snap rings (1 per side) 90520-36045
Also:
oh yea, forgot the snap ring! Thanks, I'll add them to the original post!
Edit: I actually found a different part number for the one for the inner hub. I wonder what that snap ring is for? Same thing maybe? Also, new part number for LBJ bolts w/washers are listed. Old part number was replaced per websites details.
Whatever works... I got it off a thread I knew they were in(photo), didnt reference to recent order to newest PN's
updated op with rear bearing replacement part #'s as well as a few informational quick links.
Good info here for us, [MENTION=88967]derdog34[/MENTION] & [MENTION=67079]Fjatheart[/MENTION].
Definitely, thanks for the quote.
ARKRWLR, great post. This should be continued with more parts added.
Better than looking at diagrams and guessing that is what it is pointing to.
So LBJ bolts w/ washers: 90119-10933 should be used instead of LBJ Bolts: 90080-10066 eight in all to do both sides? I'm planning on doing mine next week (starting to hear a popping sound).
Negative. Reverse that
And yes 4 per side 8 total
What other parts would you like to see? I'm trying to keep certain parts together in one thread. That way when someone not necessarily a member to the site searches Google for this particular stuff they can find this thread. If I do a mass part number thread it's only beneficial to people on the site.
Ah Ok I see the direction you are going. I just meant other replacement parts in general like suspension, engine components, etc. It's already a great list as is. Thanks for compiling it.
Might as well buy a new knuckle/spindle and have a shop assemble it since it requires the bearing to be pressed in. Take the old one off and put the new one on.
That was my plan. I assume the removal and install is straight forward?
All my parts just arrived, including knuckles, bearings and seals. Now I just need the time to wrench!
Yup, pretty straight forward. Just start taking stuff off 1 by own and eventually it will be free. Only tricky part is getting the bolt to the upper ball joint out. It's in there pretty good and hard to get a device around the UCA to press it out of there.
I wouldn't buy a new knuckle, they are quite expensive. A used one maybe, which is what I did but only because I found some for very cheap.
I would recommend you just make sure you have all the tools lined up for this, like the press, the press jigs to press out the hub and bearing and press the new one in. Check my build thread in my signature to see some of the jigs I made for this job. With the right jigs, I could do this replacement pretty quickly, but without the jigs (the first bearing I did I didn't have the jigs made yet) it is very difficult.
If you have a welder, you can make any jigs you need for this pretty easily with angle iron from Home depot.
which LBJ bolts?
I looked at both the 90080-10066 and the 90119-10933 on Camelback. They have both.
90080-10066 is listed as bolt, flange
90119-10933 is listed as bolt w/ washer
Which one is the correct part for the LBJ install on a 99 4wd?
brendaglores
