JWaldz
Moderator
Anything I've missed, feel free to let me know. I'll steadily update this post. If any part numbers have been updated feel free to post them and I will update them here.
A couple notes: I used ToyotaPartsZone because their listings are easy to follow and link. Other sites like Camelback Toyota probably have better prices but are harder to link to one individual part. Also, in the compatibility lists you might not see your vehicle in the list immediately. You must click "See All Vehicles" to expand the listing.
Driver (Left) Side
Driver (Left) Side
- UBJ: 43310-39016 (Same for both sides)
- LBJ: 43340-39465
- ITR: 45503-39075 (Same for both sides)
- OTR: 45047-39215
- LBJ: 43330-39585
- OTR: 45046-39335
- Wheel Bearing: 90369-54002 (Old # 90369-54001 - Don't Buy)
- Inner Oil Seal: 90312-95001
- Outer Oil Seal: 90316-69001
- Snap Ring: 90521-99114
- Spacer: 43524-35010 (chances are you wont use this, but it's good to have on hand!)
- Skid Control Rotor: 43515-35010 (chances are you wont use this, but it's good to have on hand!)
- Wheel Bearing: 90363-40020-77
- Type S Oil Seal (Inner/Axle): 90310-50006
- Type K Oil Seal (Outer/Shaft): 90313-48001
- O-Ring: 90301-88077
- Retainer: 42423-20010
- Skid Control Rotor: 43517-35010
- Snap Ring: 90520-36045
- UBJ Snap Ring: 90520-39180 (Same for both sides)
- UBJ Wire: 90580-10001 (Same for both sides)
- UBJ Dust Cap: 43324-39015 (Same for both sides)
- LBJ Flanged Bolts: 90080-10066 (Need 4/side)
- Steering Rack Boots: 45535-35030 (Same for both ends)
- OTR Jam Nut: 90170-20003
- Rear Axle Seals: The Ultimate Information and Replacement Thread
- R&R Upper and Lower Ball Joints
- Lower Ball Joint Removal and Installation
- Inner Tie Rod Removal and Installation
- A Possible Solution to Leaking Axle Seals
