OEM Part Numbers for 3rd Gen 4Runner: Tie Rods, Ball Joints, and Wheel Bearings
Dumb question....looked up the part numbers for the LBJ's, Camelback description shows 2wd. Are the 2wd and 4wd the same?
Thread revive..
I've got a 97 limited 4x4 but don't know which one to get! I see 95 runners and then 2001 runners, will it all fit? Sorry about the nooby question haha.
Thread revive..
what part in particular are you looking for?
Generally speaking, any part that indicates a year within the 3rd generation range will work. 1995.11 to 2002.08 means 1996-2002. If a part you're looking for only gives you a range out of your year, example: 2001-2002, it will still fit on all other years within the generation. There's a few exceptions but I don't believe they apply to any parts listed in this thread. Some parts are more updated than others. That could be a reason why it only lists newer years within the 3rd generation range. I tried to list the most updated part numbers across the board for 3rd gens only. So if it's listed, it should fit and be the most updated (unless they've came out with a more recent version then when I made this thread)
Thankyou for this! I'm going to need LBJ's and tie rod's I believe , I have a friend who works at a cadillac dealership and he said they'd be able to get the parts for cheap!
yeah.. They'll order them from the toyota dealerships at cost!
cool, I wonder whether any of the local non-Toyota dealerships around here would do that too...
AutoNation did just recently gobble up Toyota, VW, Chevrolet, etc., and my VW dealer told me he could easily have a Toyota sent over if that was what a customer desired...
Hey guys quick question
Im from Canada and im doing a full front end re-vamp just for preventative mainatnance. Im ordering from Toyotapartsoversock.com and I just wanted to make sure I have everything correct.
Inner Tie rods? (End-SubAssy,Tie Rod RH) 4504639335
(End SubAssy,Tie Rod, LH) 4504739215
LBJ (Joint Assy, Lower Ball Front LH) 4334039465
(Joint Assy, Lower Ball Front RH) 4333039585
As for the Upper Ball joints on the site there are 2 different ones one with the Part # stated in the beginning of this thread and another one, anyone know if they are the same ,both of them have an applied discount on them (41.65 and $35.90)
The cheaper one has the right part# and is also the cheaper one, Im just confirming so I don't order the wrong one.
heres a pic
Inner Oil Seal: 90312-95001 ToyotaPartsZone - Click For Part
Outer Oil Seal: 90316-69001 ToyotaPartsZone - Click For Part
Guys my Axle seal is leaking bad on the driver side front, to fix it do i need to buy both the inner and outer seal?
[MENTION=58830]JWaldz[/MENTION] suggesting another part number to add. As [MENTION=96608]MandAtaco[/MENTION] found, the jam nut on the outer tie rod can be seized and need to be replaced. The part number is 90170-20003
good find, will add it to the list!
BTW.. looks like all my links are dead b/c Toyota Parts Zone became Toyota Parts Deal. Will need to do a little updating soon. Might just remove the links all together.
Update: Links are back up
