Thread revive..
I've got a 97 limited 4x4 but don't know which one to get! I see 95 runners and then 2001 runners, will it all fit? Sorry about the nooby question haha.
what part in particular are you looking for?
Generally speaking, any part that indicates a year within the 3rd generation range will work. 1995.11 to 2002.08 means 1996-2002. If a part you're looking for only gives you a range out of your year, example: 2001-2002, it will still fit on all other years within the generation. There's a few exceptions but I don't believe they apply to any parts listed in this thread. Some parts are more updated than others. That could be a reason why it only lists newer years within the 3rd generation range. I tried to list the most updated part numbers across the board for 3rd gens only. So if it's listed, it should fit and be the most updated (unless they've came out with a more recent version then when I made this thread)
Thankyou for this! I'm going to need LBJ's and tie rod's I believe , I have a friend who works at a cadillac dealership and he said they'd be able to get the parts for cheap!
at a Cadillac dealer??
yeah.. They'll order them from the toyota dealerships at cost!
Do i need the snap ring for the wheel bearing on a 4x4?
You don't need one but they can break if you're not careful so it's always good to have a spare one.
[MENTION=58830]JWaldz[/MENTION] suggesting another part number to add. As [MENTION=96608]MandAtaco[/MENTION] found, the jam nut on the outer tie rod can be seized and need to be replaced. The part number is 90170-20003
