OEM spark plug questions
amalik
Senior Member
Do our OEM spark plugs come pre-gapped (space between electrodes) or do you have to use a tool to gap them? I was discussing this with forum member nevada and we aren't positive.
also, i've seen the recommendation to use anti-size and dielectric grease on the plugs/boots... is this necessary or just a fail-safe?
They come pregapped, and anti seize/dielectric grease is a good idea. I wouldn't drive to go get it though if i had everything else already and was ready to get started.
Good Luck
I have found most plugs come pre-gapped, but you should be prudent and check them before you go to the trouble and put them in, just to be sure.
As for anti-seize and grease, I always put both on. Its definitely not required, but the anti-seize will make changing them in the future easier.
Do use a set of feeler gages for checking the gap since they are double electrodes? Can't get the cheap round "ramp" style in there.
for sure. thanks guys. how often do you guys replace spark plugs? it's been about 70-80k since my last change, I would say I'm due.
I use NGK's (BKR5EKB-11)because a NAPA store is just down the street and the dealer is two towns away. If that were reversed, I would use Denso's(K16TR11)...both are OEM. Three of each came installed from the factory.
The NGK's and Denso's come pre-gapped (the 11 in the number indicates 1.1mm gap) but I check them anyway. Once in a while I find one needs adjustment so I recommend it. I do them every 30k like the book says. Use a wire-type feeler gauge only.
NGK recommends against anti-seize due to their tri-valent plating or some such so I stopped. At 30k change interval, this is not a problem. If I were leaving them in for 60k plus I would probably still use it. I use the dielectric grease but if I had to skip it once I would. If I had never used it, or was dealing with a new-to-me truck, I would make it a point to use it.
At 13 years and 160k, I have never had a misfire code.
Clocktower07
