Official: OEM Part Number Reference Spreadsheet
chadsy
I know I have been asking a lot of questions here recently trying to get my truck in tip top shape so I thought I would do something to contribute back to the community.
I have compiled a spreadsheet of the most popular parts & their numbers so one can quickly reference them instead of having to search and dig through various threads.
I didn't get everything and the chart can be improved so I ask you to post any suggestions, parts and/or numbers you would like to have added and I will do my best to keep this updated.
https://docs.google.com/spreadsheet/ccc?key=0Aka4wOVMLXe9dGdnZnZTTkw3MVVsRkFLNFdLLWRxQnc&usp=sharing
There were a lot of people who did the leg work of getting these numbers, I just put them in once centralized location. So thank you to them and thanks for all of the help and being such a great group of people.
Golden. Thanks man! I like this a lot! I'm stoked somebody did this!
Sweet...let's keep this updated! Does everyone have write access to the document or should we PM you/post here for you to update?
It would also be interesting to seem some sort of part compatibility information.
My suggestion for two parts to add:
Manual Transmission Shifter Bushing (end of shifter): 33548-31010
Manual Transmission Shifter Seat: 33505-35030, but alternate part number 33505-35020 from a 2nd gen also works and is a cheaper part.
I made the document a read only because there will likely be a lot of traffic going to it and something may accidentally get messed up. If you just respond to this thread I will make the additions.
I think that's a great idea about the alternate part numbers. I will add a column for that. There's also a column for notes there already that I can add information about the part to.
Or get these from Marlin Crawler, I just did as part of my clutch job:
Heavy Duty Shift Lever Ball Seats | Marlin Crawler, Inc.
Heavy Duty Shift Lever Socket | Marlin Crawler, Inc.
I have quite a few, but not all the numbers. My niece last summer killed my old laptop that had over three hundred numbers plus the dealer spreadsheet that showed part numbers that related to positions on the 4runner. I even had a friend (NSA computer whiz) try to recover the data but salt water holds no punches. I even promised Kball (Kevin) my numbers, but I have only been able to compile an Excel spreadsheet from old receipts.
Toyota CV Boot repair kit: 04438-35060. Comes with two boots, two grease packets, and clamps.
I contacted LC about making a part number thread a while back since I knew from his posts he had lots of numbers. But, as you can see his niece killed that plan LOL. Here's my mess of numbers I've compiled. It's a mess and I'm sure there's duplicates. I just keep throwing stuff in there and I'm too lazy to make it nice. Have at it.
90341-24014 Front Differential Drain Plug
90341-18057 Rear Differential Drain Plug
90341-18006 Rear Differential Fill Plug
12157-10010 Front Diff Fill Plug Gasket / Rear Fill Gasket / Rear Drain Gasket
90430-24003 Front Diff Drain Plug Gasket
90430-18008 Transfer Case Gasket
90341-12012 Oil Drain Plug
90430-12031 Oil Drain Plug Gasket
90341-10006 Transmission Drain Plug
35178-30010 Transmission Drain Plug Gasket
TOY 90430-18008 TC Fill/Drain Gasket 27 Ft-Lb
NAPA ATM PB2403 TC Fill/Drain Gasket 27 Ft-Lb
TOY 12157-10010 Front Diff. Fill Gasket 29 Ft-Lb
TOY 90430-24003 Front Diff. Drain Gasket 48 Ft-Lb **90341-24014 10mm hex drain plug, better than orig 12mm hex**
TOY 90341-18006 Rear Diff Fill Plug 36 Ft-Lb 24mm skt.
TOY 12157-10010 Rear Diff. Fill/Drain Gasket 36 Ft-Lb
TOY 90430-18008 5-speed Fill/Drain Gasket
NAPA ATM PB2403 5-speed Fill/Drain Gasket
Stock height Bilstein rear shocks W0133-1910827
Land Cruiser shocks part# BE4095 or 48531-69417
Trekmasters is GE4095
black tokico toyota landcruiser oem shocks. Part number on shock is: 48531-60430
O2 sensor nuts Part #90179-08059 or any stainless M8-1.25
1996-1998 Auto 4WD V6 3.4; Front = 234-4162
1996-1998 Auto 4WD V6 3.4; Rear = 234-4154
PCV - NAPA Echlin Part No. CRB29352 costs $3.87
Grommet is 90480-18001 NAPA Echlin CRB 29121 works and is $3
NGK spark plug is #BKR5EKB-11. Denso plug is #K16TR11
NGK TE66 wires or Denso #671-6182
Starter rebuild
28235-54380 Plunger magnet switch
28226-54340 Kit starter repair
28226-72010 Starter kit
Steering rack guide
End sub-assembly, steering rack no. 2/ Guide sub/assembly
45504-35031-
Spring(for steering rack guide)/Spring, compression
90501-26074-
cap, Steering rack guide spring/ Cap, rack guide spring
45524-37010-
Nut(for steering rack guide spring cap/ nut
90179-48003-
Crankshaft front pulley bolt
90105-16031 -for those assembled BEFORE 10/98
90119-16006- for those assembled 10/98 up through 2002 models
Kuzeh T stat
W0133-1633966
the two seals for inner side of the cv axle are.
Toyota 90311-47013 1 $ 11.88
Toyota 90311-47012 1 $ 7.15
cv dust cover part# is 41336-35020
Valve covers - 11201-62040 (Right) and 11202-62050 (Left)
-Valve cover and assoc gaskets-
FIPG part# is: 00295-00103
2-Valve Cover Gaskets (both the L & R side are the same part), Part #11213-62020
6-Spark Plug Tube Gaskets, Part # 11193-16010
2-Intake Plenum Gaskets (both the upper & lower are the same part), Part # 17176-62040
16-Washer Seals (for the valve cover bolts) Part # 90210-05007
Camshaft housing plug(2): 11188-62010
Fuel Pipe washers (4 needed): 90430-12026
Valve gasket- 11213-62020 x 2
Plenum gasket- 17176-62040 x 2
Half moon- 11183-62010 x 4 (can be cleaned and reused)
Cam plug- 11188-62010 x 2
Spark plug gasket 11193-70010 x 6
PCV- 12204-62010
Grommet for PCV- 90480-18001
gaskets needed for valve cover replacement
Qty#- Name- Part#
(1) PCV valve 12204-62010
(1) PCV grommet 90480-18001
(2) Valve Cover Gaskets (Left/Right) 11213-62020
(6) Spark Plug Tube Gaskets 11193-16010
(2) Intake Plenum Gaskets (Upper/Lower) 17176-62040
(16) Washer Seals (For Valve Cover Bolts) 90210-05007
(2) Camshaft housing plugs 11188-62010
(4) 1/2 moon 11183-62010 (can be cleaned and reused)
(1) Tube of FIPG 00295-00102 or 00103
(1) Oil Filler Cap Gasket 90430-3714
a/c / heat control knobs 55905-89115
RH LBJ: 43330-39585
LH LBJ: 43340-39465
4 bolts for each side of LBJ (8 total): 90080-10066
tie rod outer RH: 45046-39335
tie rod outer LH: 45047-39215
O/2 sensor nuts PN# 90179-08059 (S/S nut M8-1.25)
AC receiver/dryer for $40 from the dealer. Part # 88471-34010.
FIPG: 00295-00102 or it may be 00103 now.
Fuel filter- 23300-62030
throttle body gasket - aftermarket
FEL-PRO 61038
injectorwarehouse.com, part #MP4075-6
Denso OEM part #23250-62030
Walker cat converter is one of the only after-market manufacturers with CARB approval for the V6. (Part No. 81712)
Longer studs for wheel spacers 27865-B
CV reboot kit (this one I think)04438-35060 or 04428-35010
filler pieces under headlights
52512A FILLER, FRONT BUMPER, RH
52512-35030 RZN18*, VZN18* 1 $28.98
52513A FILLER, FRONT BUMPER, LH
52513-35030
Brakes- front ceramic pads kit for 231mm calipers (comes with shims supposedly) $56
04465-AZ001-TM
Brake lines:
part# (same for both sides):90947-02862
tube that goes from the line to the caliper:
right: 47314-35330 and lists for $7.96
left: 47316-35250, also $7.96
Vacuum check valve for brake booster
44730-60060
grommet - 90480-2415
CANISTER ASSY CHARC [Part# 7774035392]
99 tall springs
Front right 48131-35400 L=368mm
Front left 48131-35350 L=374mm
48231-35210 (same for both) - 1999 Rear tall coils (2)
94183-00831 - Rear endlink top nut (2) - FSM says non-reusable part
90105-12288 - Lateral control arm bolt (2)
94622-31200 - Lateral control arm washer (2)
90170-12039 - Lateral control arm nut (2)
steering rack P/N 44250-35042
hard brake lines 99 runner possibly all?
right side is 47313-3D050
left side is 47315-35320
Steering Rack Guide - 4Runner OEM
45504-35031 - End sub-assembly, steering rack no. 2/ Guide sub/assembly) - Qty 1
90501-26074 - Spring(for steering rack guide)/Spring, compression - Qty 1
45524-37010 - Cap, Steering rack guide spring/ Cap, rack guide spring - Qty 1
90179-48003 - Nut (for steering rack guide spring cap/ nut - Qty 1
43430-35030 - CV Axles - Qty 2
Wheel well engine covers
The big front one on both sides: 53735-35030
The small rear one on the pass side: 53887-35010
rear axle bearing and seals
90301-88077, O-Ring x2
90310-50006, Seal, Type S Oil x2
90363-40020-77, Bearing x2
42423-20010, Retainers x4
43517-35010, Skid Control Rotor x2
90520-36045, Snap Ring x2
90313-48001, Outer Shaft Oil Seal x2
Blower motor resistor 87138-35050
Engine dipstick o-ring #96721-19010
Two of each required per side:
Lower Control Arm Alignment Cam w/ Sleeve: 48409B
Lower Control Arm Alignment Cam (Nut): 48452A
Lower Control Arm Bolt: 90119-14071
Outer TRE lock nuts: 90170-20003 (includes 2)
96 runner glove box bulb 90981-11018
tacoma shifter bulb ^^same^^
Camshaft Position Sensor Assy P/N 19300-62010 $106 (with mount?)
just the sensor is $88+ 90919-05021 (sensor without the mount, it appears)
Bell Crank Bracket (47628-35020)
Bell Crank Boot (47633-35020)
Bell Crank Pin (90249-08068)
Bell Crank Washer (90213-06013)
ECT sensor wire harness (from plug to sensor?) 82219-34020
Tacoma antenna whip assembly (comes with silver mast) 86300-35090
rear wiper #85214-YZZD3
Oil cooler orings and hoses
#90301-67004 for the one that goes between the block and the cooler itself.
#90210-22001 for the one under the bolt that holds the cooler to the block.
two hoses:
#15777-62020
#15778-62030
NGK spark plug boots
58931
Weather stripping
6816335030 rear door, door & components, belt wstrip Right $16.27
6816435030 rear door, door & components, belt wstrip Left $16.27
6816135060 front door, door & components, belt wstrip Right $16.27
6816235060 front door, door & components, belt wstrip Left $16.27
6829135021 lift gate, interior trim, inner wstrip $27.42
bilstein stem adapter kit for rear shocks. part number B4-BOA-0000228
rear hatch 69023-35010 Its the handle, return spring, and mounting plate assembly for anyone thats interested.
ADD ACTUATOR ASSY DIFFERENTIAL VACUUM Part number 41400‑35020
Brake pedal pad 47121-12011
Driver side front wheel bearing parts:
Bearing: 90369-54002
ABS "Skid Control" Ring: 43515-35010
Inner "Type D Oil" Seal: 90316-69001
Outer "Type V Oil" Seal: 90312-95001
"Hole Snap" Ring: 90521-99114
PCV
TOY 12204-62010 PCV valve
NAPA CRB 29352 PCV valve
TOY 90480-18001 Grommet for PCV
NAPA CRB 29121 Grommet for PCV
Front grill clips- 90467-12040
Toyota OEM ball joint and tie rod part #'s
Driver (Left) Side-
UBJ: 43310-39016 (Same for both sides) ToyotaPartsZone - Click For Part
UBJ Dust Cap: 43324-39015 (Same for both sides) ToyotaPartsZone - Click For Part
LBJ: 43340-39465 ToyotaPartsZone - Click For Part
ITR: 45503-39075 (Same for both sides) ToyotaPartsZone - Click For Part
OTR: 45047-39215 ToyotaPartsZone - Click For Part
Passenger (Right) Side-
LBJ: 43330-39585 ToyotaPartsZone - Click For Part
OTR: 45046-39335 ToyotaPartsZone - Click For Part
Front Wheel Bearing Part #'s (Non side specific)
Wheel Bearing: 90369-54002 (Old # 90369-54001 - Don't Buy) ToyotaPartsZone - Click For Part
Inner Oil Seal: 90312-95001 ToyotaPartsZone - Click For Part
Outer Oil Seal: 90316-69001 ToyotaPartsZone - Click For Part
Snap Ring: 90521-99114 ToyotaPartsZone - Click For Part
Spacer: 43524-35010 ToyotaPartsZone - Click For Part (chances are you wont use this, but it's good to have on hand!)
Skid Control Rotor: 43515-35010 ToyotaPartsZone - Click For Part (chances are you wont use this, but it's good to have on hand!)
Rear Wheel Bearing Part #'s (Non side specific)
Wheel Bearing: 90363-40020-77 ToyotaPartsZone - Click For Part
Type S Oil Seal (Inner/Axle): 90310-50006 ToyotaPartsZone - Click For Part
Type K Oil Seal (Outer/Shaft): 90313-48001 ToyotaPartsZone - Click For Part
O-Ring: 90301-88077 ToyotaPartsZone - Click For Part
Retainer: 42423-20010 ToyotaPartsZone - Click For Part
Skid Control Rotor: 43517-35010 ToyotaPartsZone - Click For Part
Snap Ring: 90520-36045 ToyotaPartsZone - Click For Part
Other Miscellaneous Corresponding Parts
UBJ Snap Ring: 90520-39180 (Same for both sides) ToyotaPartsZone - Click For Part
UBJ Wire: 90580-10001 (Same for both sides) ToyotaPartsZone - Click For Part
LBJ Bolts: 90080-10066 (Need 4/side) ToyotaPartsZone - Click For Part
Steering rack boots (x2): 45535-35030
LBJ bolts w/ washers (x4 per side): 90119-10933
LBJ Bolts (flange type??): 90080-10066 (Need 4/side) $1.22/ea.
PS adjustment bracket (slider) 44469-35010
sun roof Motor is Part No. 85730-35030 All 3g. But that is just the motor. The gear sub-assembly is 63260-35030. That seems to include the motor.
TOY 90189-06212 Fender Lining Grommet
NAPA Balkamp 665-1378 Fender Lining Grommet
timing belt and head gasket parts:
1 Head Gasket Kit Fel-Pro HS9227PT1
1 Head Bolt Set Fel-Pro ES72168
1 Timing Belt Toyota 13568-69095
1 Idler Roller NSK OE 13503-62040
1 Tensioner Roller Koyo OE 13505-62070
1 Front Crankshaft Seal Toyota 90311-40022
2 Front Camshaft Seals Toyota 90311-38051
1 Water Pump Aisin OE 16100-69398-83
1 Water Pump Gasket Aisin 16271-62011
1 Hydraulic Tensioner Toyota 13540-62021
1 Thermostat (82°c) Toyota 90916-03075
1 Thermostat Gasket Aisin 16325-62010
? Head Bolts #90910-02077
? Head Bolt plate #90201-11028
99 year model
AC idler pulley assembly: 88440-35060
ITR bellow clamp: 90460-62006
Water temp gauge assembly (the one for the dash): 83420-16020
Brake booster gasket: 44785-0C020
MC gasket to brake booster: 47275-12020
LBJ bolt (need 4 for each side, may be different for 01,02): 90080-10066
IAC gasket: 22215-62180
Brake shoes: 04495-35230
ECT sensor: 89422-35010
ECT sensor gasket (brass): 90430-12005
Fuel delivery pipe O-ring (the crush gaskets): 90430-12026
5VZ
radiator hose upper: 16571-62070
radiator hose lower: 16572-62070
3RZ
16572-75090 and 16572-75180
MAF replacement screws (at least for 99+): 93319-14010
90480-15028 Grommet (for hood support)
Wheel well grommets- NAPA has them, $5.49 for 5 which is more than you need to get the antenna out (Balkamp 665-1378) or dealer has them for $1.01 each (90189-06212)
90189-06028 = fender liner screw grommet
Antenna hole cover 55796-89102
Cover Switch Hole
The one above is black and goes next to the dash dimmer (55539 in diagram below).
The one below is the large square one that goes in the surround and is trim color(55524):
COVER, SPARE SWITCH HOLE
55524-35020-B0 MD.MOON MIST, TRIM1* 1 € 7.24
55524-35020-E0 OAK, TRIM4* 1 € 8.01
This is the smaller colored one that goes a few places(55539D,E,&F) in the surround and what I think you want:
55539F COVER, SPARE SWITCH HOLE
55539-20080-B2 MD.MOON MIST, TRIM1* 1 € 5.71
55539-20080-E0 OAK, TRIM4*
55539-20080-B3 DK. CHARCOAL
rear wiper
85247-35010 slider subassembly
90099-00925 Screw X 2
Sensor Harness - 82219-34010
Knock Sensor - 89615-12090
FELPRO Manifold Set - MS 95898 (Not OEM but it's good gasket set)
front LCAs
Front right part #: 48068-35081
Front left part #: 48069-35081
valve cover bolt
90105-06127
a/c idler pulley
4runner - #8844035060 and is $41 on Camelback.
Tacoma, replaceable bearing #8844004040 and it's $31.
Rear upper control arm bolts
90105‑12287 - Bolt
94622‑31200 - Washer
90170‑12039 - Nut
TOYOTA OEM FACTORY DRIVERS SIDE EXTERIOR DOOR HANDLE ROD CLIP 69293-12040 (yellow plastic clip)
INJECTORS
Purchased from NAPA
Kit for One Injector - Upper and Lower O-Ring
PART #CRB 212077
Currently $2.70 /Kit at my store
Purchased from Dealership
Fuel Rail Crush Washers - need two per side
Part#90430-12026
Paid $1.70 each
Heater control valve 8724035050
thermostat gasket Toyota part # 16325-62010
My niece is a wicked little woman. It must be the red hair. I swear she put the computer in the water on purpose. And my sister still thinks nothing of it. B$%&h!
Here are a few I have lying around (all these parts are for a 99, so check application per model year):
I will post more when time allows.
:roadkill:
Wow! What a great response! I have updated the spreadsheet to include many of the part numbers provided in this thread. Enjoy!
Here are three more part numbers that may be relevant for others that I found:
Thank you thank you thank you!
This is the best thread ever. What a lifesaver to have the right part numbers!!! Thank you!
:dance:
Jhunt
