Offroader5
Not much of an update, but something else crossed off my list, so it's a start.
After being without front door panels for quite some time while I stewed over what components to install, I finally got them in.
I did alot of research on components and after narrowing it down to several different brands/sets that ranged from about $300 up to $500, I settled on a set not even in that list. I found great reviews on these components and as inexpensive as they are...decided to just go for it. Ironically enough, the OEM JBL Synthesis speakers have been replaced with JBL
The MS-62C 6.5" components.
Made a bracket out of acetal plastic for the tweeter, and a 3/4" MDF baffle board/adapter to fit the 6.5". The area directly behind the woofer received a square of Ensolite acoustical barrier from RAAM Audio to help break up the waves coming off the rear of the woofer. I also put some over the top of the deadener where the larger holes were in the door and I used it as a gasket material between the MDF baffle and the door sheetmetal.
Sounds Incredible. Right now they are being fed about 80 watts per door, but will see closer to 100-120 when I get my new 4 channel amp later.
Sorry, the pic with the woofer came out a bit fuzzy
