vicpick58
With so many people having to pry and scrape off the drain plug gasket, perhaps it's just supposed to stay there for a few years? I could see how a "semi-permanent" gasket would be helpful if an owner was getting their oil changed at places like Jiffy Lube and Walmart, which are less likely to have to correct gasket.
Can someone confirm this in a real TMC shop manual? I don't have one.
I just left it there for the first 2 or 3 oil changes, it did not leak a drop. It eventually came off with the plug in a later oil change, at that time I replaced it with a new copper one.
I do not change these plug crush ring/gaskets every oil change. Maybe I am supposed to, but so far no oil leaks. I DO however use the filter drain and replace both O rings in the filter canister every time. I do not Bubba tighten the plugs, just snug is fine.
By the way I end up changing oil about every 6 to 8 weeks @ 5k intervals. So if it ever does drip a little it will not be for all that long, but like I said no evidence of oil dripping so far.
So don't sweat it if you have not changed the plug gasket. Just do it next time if it makes you feel better.
