Oil Change 5th Gen: How To- LOTS of PICS!
Simple used to be taking it to the dealer. I got 4 years of free oil changes when I bought my 2016.
So I took it to the dealer for my lifetime free annual state inspection and got an oil change prior to leaving for the beach. Picked it up and drove 10 miles back home.
One bolt was gone and the other one fell off when I touched it. The service writer and the service manager were like, "Jeez, just when you think you've seen it all."
Funny, but I saw that on another 4Runner at a stop sign while walking my dog. Tried to tell the Lady driving it but she sped off thinking maybe I was going to car-jack her or something. I know I have a face for radio but didn't think I looked that scary.
Does anybody just skip the drain valve part and just take out the entire oil filter and drain that and then put it back? I don’t even mess with the small o ring valve bc it’s too tight to get off and the entire oil filter canister moves when you loosen it.
I've done it that way and no issues
Yep, I always do the filter change that way. Not really that messy doing it like that.
Torque for the drain valve plate is ~ half of the canister torque. Your’s is just over torqued.
10 ft-lbs for drain valve
18 ft-lbs for housing.
Well I just tried it without using the drain tap for the filter and think I will use it next time. Got oil everywhere. Maybe saved me 10min.
Last oil change was done by the dealership under the toyogard plan and I was coming up on needing one. I'd previously purchased the metal filter housing and an EZ flow drain valve and filter, so all I needed was the oil..
The entire process took a bit longer that expected. For one, the tech who installed the plug at the last change must have really cranked down on it, the crush washer was pretty well stuck to the pan. Also, I've got an RCI front skid, so that had to come off to install the EZ flow drain valve..Otherwise, everything went super smooth and will take a fraction of the time on the next change..
Did have a question for anyone who has used the EZ flow valve..They have an o-ring on them instead of a gasket..I didn't put a new gasket on, just cleaned the surface and used the o-ring..no leaks, but wanted to see what other have done..thanks.
I think I am going to avoid ever having the dealer change the oil. They seem to always damage something while they are in there.
Good decision. I didn’t use my “free” oil changes, because everything has a cost.
Dealership (and probably most shops) use the lowest experience techs for oil changes and other “simple” jobs. They also pay per job, not per time it actually takes you to do it, so the tech is incentivized to do it fast. Quantity > Quality is the opposite of my Modus Operandum.
Yeah, that’s what happens when you go to Toyota for a free oil change. I stopped using them. Worried about them messing up anything else.
What a pain!!!
Change your oil they said. It'll be fun and satisfying they said!
What a pain in the arse!
Now, I'm no newbie to oil changes. I've done it for many years on many different cars with no issues. Done quite a bit of work under the hood on Hondas, Mitsubishis & BMWs. That said...it is a pain.
The first problem was totally my fault and partly Toyotas. Why can't Toyota include a drian plug washer in their oil filter box? WHY? So, months ago, I ordered a bag of washers and stashed them away in a drawer. Yesterday???
NOWHERE to be found. I found it (of course) in the drawer I put it in...That was a 30 minute detour of my plans. And now I've just overturned the rest of my garage looking for a washer. WHATS GOING ON TOYOTA?
Next, I *tried* to do the oil change without lifting the truck. BIG MISTAKE! I'm pretty slim, but I could barely get my head to fit under the rear skid plate.
Anyways, the rest of the oild change went without too much drama. The weird oil filter design and oil filter housing drain thingy didn't pose any problem. The oil filter was on TIGHT though.
Trying to pour the oil from the drain pan into my oil jug was a major pain as it rivalled the Exxon Valdez in 1989. It was a new oil pan to me and very poorly designed.
PSA: The plastic skid plate bolts are made of peanut brittle so go easy on them. I snapped one of mine off.
All in all, why is a 'finicky' German car (2004 BMW ZHP) so much easier to do oil changes on? I don't even have to crawl under the car as the filter is up top and I use a fluid extractor.
Yeah, I have never used a valve or one of those drain tools which is why I was curious.
I had watched this after getting my 4Runner back in December
https://www.youtube.com/watch?v=cUPUzN7h9zU
And then started reading about the PITA of the bolts on the stock skid plate being a pain when they get a bit corroded so ended up picking up an after market skid plate with a seperate cover for the oil filter so I can just forgo having to remove the entire skid each time. lol.
Free Shipping Bumper Skid Plate Protector Guard For TOYOTA 4RUNNER 2010-2022
Does that plate work on Limited too?
lindwlson982
