Oil change interval
I paid to have my first local dealer oil change at 1,500 miles and saved first catch oil into plastic bottle. Wow, very black. Let it sit in garage for 6 months then poured it into a bigger container for a used oil drop off. The black grit sludge that settled out and stuck bottom of bottle was dramatic.
Later learned from same dealer's courtesy driver that the experienced shop mechanics assign truck oil and tire rotation jobs to newbie mechanics then place bets on how fast they complete the job!
Now I only service my SR5 where I can watch the mechanics work.
A poll on what interval owners use would be great.
I was planning on every 5,000 miles as a form of "cheap insurance". I do want this thing to last forever. I suppose I could do 7,500. I don't think I want to humor 10,000.
10000 here. Just don't see the need to do it more often with synthetic and typical use cycle I put it through.
I just got my Blackstone report back for my 5,000 mile normal change interval using an OEM filter and Kirkland Full Synthetic 0-20w and just normal city/highway driving on my 2017 with 60k miles on it. No consumption or oil added during the interval. They said it looked perfect and advised that I could go well beyond the 5,000 mark that the car tells you to do. I'm going to try 7,500 next time and see what they say. Can't beat the Kirkland for the money!
I’ve been running Kirkland synthetic at ~12,500 intervals for the last 200,000 miles. Last report showed still had plenty of life left.
At least during the warranty period, I'll be letting my dealer do the oil changes. After the warranty period... I'll probably still let them do the oil changes.
Would be nice to know if they're using quality oil. I wonder if I would get a truthful answer if I called and asked what oil they use?
I do the same. Dealer by me 1hr away is actually pretty good and they use Toyota synthetic so i know its good.
I allow the 5,000mi reminder go and usually do between 6k and 7k, with the rare 10k if necessary.
There aren't many options out there for 0-20 and it's only synthetic. If they aren't using Toyota my guess is it's Mobil 1. Unless there is some bulk oil from Warren or something I don't know about that dealers can get. Warren makes Kirkland, Amazon, and some other big brand oils. They're fine.
They have to use oil that meets the API standard required for your vehicle. Are there oils that are much better than the minimum API standard? Yes. Is the dealership using said oils? No, they are running a business that needs profits to stay afloat.
If you plan on never doing the oil changes yourself, then go ahead with dealer service.
If you do plan on doing oil changes and other work yourself, don't let the lowest paid tech who is paid by the job, not the hour, touch your truck.
Man, I got the free oil change and rotate at 10k miles. I went back over it.
The lugs were loose as were the skid plate bolts never again.
My issue is I love to wrench to if oil is due on a car I am ready. 5k is my interval on things but I will send in an oil sample at 15k miles.
You can get your 6.5 quarts of Mobil 1 at Walmart for $35 or less. Quaker State is even cheaper and just as good, some studies say even better in some aspects. Toyota OEM filters off Amazon for $42 for 10 or $4.20 apiece, delivered. So really we’re talking an oil change for less than $39 and 20 minutes of my time. I’d spend more time just getting it to a dealer, let alone the wait and getting it back home. Then there is the issue of minimum wage lube techs stripping the bolts out on your skid plate by zipping them back in with a cordless impact. All that said, I still change at 10K intervals because the synthetic holds up and 95% of our miles are interstate highways.
No matter how hard I tried, my best time to change oil from jacking up the car to lowering it back is always more than an hour even when I lined up the tools and materials required in perfect order. 20 minutes seemed impossible for me. Do I miss anything here?
No, you didn't miss anything. I take more than an hour to change oil and filter and spend extra time inspecting other items while under the vehicle. I take pride in the way I do it; I am working for myself.
Tons of experience and skill. This task is a no brainer.
