Oil change tricks to make the job easier and less messy?
I leave the skid off and just stick my hand up there. The oil usually flows down my arm into my armpit.
Oil on the frame bothers me not so I wipe what I see and leave the rest.
So I'm by no means a skinny guy. I'm 6'0" and weigh 215 lbs. How is it that I am able to unscrew the oil filter from the top and change the filter with hardly a drip, and almost everyone else is forming funnels to catch the deluge of on-rushing oil? I think I might be doing it wrong? Are you changing the oil hot, with the filter full? Maybe I'm doing it wrong, and I'm completely open to feedback, but I change it in the AM, cold, and just take my time letting the oil drip out. Not much filter spill at all...because the filter is empty.
Let it drain...tidy up the work bench for a few minutes...take a whiz...go back to your rig and it'll be finished.
Again, completely open to a rational, well formed critique of this method but this simple way is much easier than removing wheels, shields and skids.
I always change oil when the engine is hot. Perhaps it doesn't really benefit us to do so, but I haven't done a scientific analysis to prove either way, so I go with the often bogus reason of "just because...I've always heard...). I let it set for a little while as the oil pan drains, to let it drain fully and to let the filter cool off some. To me, it seems that the oil doesn't drain much from the filter. Perhaps it would if I let it set longer.
I snug the filter back on, just a little, with a wrench. Just for extra mental assurance. If I find that I can remove the filter from the top, then I will stop snugging it (while keeping a close eye out afterward for leaks).
Drips on my chassis don't bother me at all. Drips on my basement floor bug the living chit out of me. Especially when it leads me to believe that I have a real oil leak.
I will do some experimenting during my next oil change, using some of the tips above (like situating my Form-a-funnel more vertically) - thanks for that tip. I have tried the plastic bag trick previously, and that didn't help much at all. Perhaps if I let the filter drain longer, that trick might work. I have tried stuffing a bunch of paper towels under the filter. That helped some, but not enough.
I take my 2WD T4R offroad frequently, so I am leaving my skidplate on (which is a PITA to remove). As a side note, I continue to be amazed at how well a 2WD T4R can do offroad. Haven't gotten it stuck yet, but that day is coming. Reason why I always carry a Come-a-long and 150' of rope in the back. :biggrin1:
The conventional wisdom has always been to change oil from a warm engine, because the oil flows better and more of the dirty stuff comes out. Letting it drip cold is not a substitute. So I disagree with that.
What does help is to leave the filter alone for a good while AFTER you drain the warm oil out of the pan drain. I do that and it reduces the filter spill a lot. Just don't forget you let the oil out and drive off that way.
Why is your filter empty?
I go in thru the top with my hands to take out the oil filter. If for whatever reason its on there pretty good, I'll use an oil filter socket with an extension through the wheel well access panel.
Only way to keep the oil filter mess to a minimum is to put a rag in there.
Agreed...not empty, but the oil certainly won't pour out at the same rate when hot.
I like the idea that was posted about changing warm, then letting the filter sit a good long while so it drains properly. Best of both worlds. Thanks!
Okay, here are some pics of the oil change.
1st pic shows the plastic bag I used. I did spill some and that was my mistake for not using a bigger bag as I have in the past. I always have cardboard on the ground just in case. Next time I will try the tin oil in addition to the plastic bag to make a better seal.
2nd pic shows the oil filter under the wheel well with the rubber flap open
3rd pic shows the bag under the oil filter
4th & 5th pics show the ValvoMax drain valve. If I had to do it again I would buy the fumoto value, easier to use and less parts. You can see in the last pic oil dripping out so the valve might have issues.
I also use the larger Toyota oil filter (90915-YZZD3) so that makes it easier to remove since it has more surface area. Truck has mild lift and the lower plastic valance on the bumper has been removed so that also helps.
peacefulpiranha
