Oil: how much oil for drain and filter replace
ron in sc
I can not find the place in the manual that says quantity of oil to be replaced when engine drained and filter changed. I must have missed it.
So does anyone have this information?
Which vehicle?
i don't have the manual in front of me. I believe its under a section called fluid capacities.
I know how to change the oil that was not a problem. I just can not find capacity section in my owners manual. Vehicle is 2012 4runner.
Below is photo of oil filter housing hiding up there, behind those panels.
I think the manual says 4.5 quarts? My mechanic put 5 quarts in at my 1,000 mile oil change.
5 qts????:wow:
You need to check your oil level on your dipstick then.
It takes 6.6 quarts but I have just been going with 6.5 and she never burns a drop.
I wish someone FRIENDLY AND HELPFUL would do a writeup on oil changes for the 5th gen... Maybe we could get it into one of those pinned threads.
I have been using 2.5qts of oil, no problems! TOTALLY unrelated, I'm sure. My engine has been making an odd noise and seems to be grinding a bit. Is there a TSB for this?
:D
:D
...and if someone were to do that writeup, maybe they could show how much oil to use 4 times in the first post in case someone were to miss the first 3.:redbrick:
Mine took 6 quarts and 14 oz.
That 6.6 quart figure I read about in other threads may be based on a dry fill for a new engine. I have never found it purdent to put in the dry fill amount straight away. If mine needs a little more I'll add it after checking oil when engine is at operating temperature.
I first put in 5 1/2 quarts. then ran engine a few minutes, check oil on dipstick and added more oil, repeated and then added a little more. With total as indicated above.
I'm sure everyone knows not to fill or add oil above the top notch when the engine is not up to operating temperature due to thermal expansion of the oil.
Oil Change
First off it is in your manual under specifications. It is 6.6 qts. for refill with filter replacement. You can always check your dipstick a few minutes after filling and it will show you the level.
Dry fill on a New engine would be the most oil. So, 6.6 -vs- 6qt.14oz. is more.
The numbers in the manual are estimates, to many variables....
My advice to anyone would be 6.5 qts. and then check the dipstick.
A little less is better than a little more but honestly neither are going to cause a problem unless it is extreme.
Does anyone really believe that wasn't factored into the design?
Honestly, this thread serves no purpose other than to muck-up future searches (which would have avoided starting it in the first place).
I vote it should be deleted.:dammit:
I second that motion, too much hard work, Good work done by AntMan to muck up access to future seekers of knowlege.
