oil leak from steering box
jereli
So I have 1991 4runner that has an oil leak that appears to be coming from the steering box. There is lots of oil that drips down from the front driver side near the bumper. Is there a o ring or something that can be replaced? I can post pictures later if needed
These can be rebuilt. Google this site and you will find info on how to do it. If it's not too bad, sometimes Lucas Stop Leak will slow down the leaking, but that's a bandaid not a fix, it'll eventually need to be fixed correctly. In the meantime, keep checking your power steering fluid level and keep it filled appropriately so you don't burn up the motor and cause more problems. Oh, and put some cardboard or a bowl under it so it doesn't leave a puddle in your driveway :-)
Mike
I just bought a rebuild kit off ebay. Fairly straight forward and not a big deal. Only PITA is the rear c clip that holds the backing plate on.
You can also buy remanu power steering pump for not much money if you just don't want to deal with it.
Cleaned up the steering box with degreaser and found where the leak was coming from. Was leaking from where the hose enters the box. I believe its the inlet. Replaced hose with a fresh one and leak stopped so far. Can I buy just the inlet fitting? It may be slightly bent.
H.Sikina
