Then again, if you plan on going anywhere like work, for instance, don't worry about the leaks.
First of all, resorting to personal insults really does not attract intelligent readers.
Second, your 18 year old engine will leak oil if it has seen any use.
There's a practical side to using it for it's expressed purpose i.e. going somewhere and doing that within reasonable parameters. Most of the bigshot grease monkeys here couldn't make it across state boarders let alone coast to coast. They've never gone anywhere and couldn't do it if they actually tried.
Damn, mine is 19 years oldI wan't an oil like like the cool kids.
So... I replaced the o-ring on my distributor and I'm still leaking. I went and bought the $7 o-ring from the stealership just to be 100% sure that is not where it's coming from. The more and more I look at it I wonder if my power steering pump is what's leaking. Eventually I'll end up with a ram assist for my steering so I'm thinking about this:
Toyota, Suzuki Samurai, and Jeep Off Road Parts
The two bottles of STP Stop Leak which I added to the oil has helped. I notice an obvious slowing of the leaks. It is still dripping so today I may crawl under the vehicle and wash it off again. Nevertheless, the dip stick shows a full engine and has been giving a steady reading.
Thanks for the advise but I would rather just fix the problem instead of using a band-aid.
The idler arm is on the passenger side of the runner and there isn't any evidence of fluid anywhere near though. Thanks for the idea though.
If I was burning oil, would oil evidence be obvious on the o2 sensor and easy to identify between carbon buildup and oil deposits?
