If you would read your own reference carefully, they are saying that the reason to run the conventional oil for the first 500 miles is to clean out as much of the wear metals as possible then switch to synthetic(Amsoil in this case).
Maybe you should read it carefully. I never said the REASON why they claim you should break a new engine in on conventional oil, I simply provided PROOF that they do recommend conventional oil for break-in.
"First, if you have a brand new vehicle we recommend that you run a short cycle of petroleum oil on a gas engine passenger car"
There it is in black and white. Go argue with Amsoil, not me.
There has to be a small amount of oil to lubricate the rings or they would sieze in the bore and scuff the piston ring grooves which would quickly result in engine failure. Maybe you need to take a refresher in Engines 101.
Who said that no oil should be present? Certainly not me. I would never advocate running an engine without oil present.
You never explained how the engines that come with synthetic from the factory are engineered for it?
Please explain the engineering differences between an engine with synthetic as the factory fill and and engine with conventional as the factory fill.
Sure I did... probably 2 or 3 times already. Do yourself a favor and perform a web search on cross hatch patterns and the different kinds of piston rings. I'm sure you'll believe your own research much more than you'll believe me.
I bet the answer lies not in engineering differences, but cost. If you look at the engine's that come with synthetic as the factory fill, they are usually higher performance sports cars with a higher than average cost. I'm not aware of a vehicle that costs less than $45,000 sticker that comes with synthetic as the factory fill.
So using that dumb logic, if Toyota decided to make my 4Runner a $45000 vehicle and call it a sports car, it would come with synethic oil in the crankcase??
You are showing your ignorance about modern engine technology if you honestly think a Corvette engine or an M3 engine that comes with synthetic fill is not engineered for it.
You haven't shown any solid data to support any of these claims either. These are purely YOUR opinion on a subject that you know little about.
You have only stated YOUR opinions as well. A lab test result doesn't do anything to COMPARITIVELY compare two otherwise identicle engines.
I am sure many appreciate your insightful information on other subjects, but do everyone a service and don't propagate these false opinons. It's hard enough to wade through the BS on the internet without people such as yourself blatently advocating incorrect practices. This thread is a perfect example of why there are so many threads inquiring about synthetic oils versus conventional oils.
I'll continue to state my opinions and back them up with facts if I feel the need. Don't tell me what to say or not to say, m'kay?
Perhaps you should take your own advice though...
