Oil temp
none, at least not that I've come across :tape:
I don't think we have an oil temperature sensor...only custom temperature codes I've used are the ones for the transmission fluid temperature. There's also coolant temp and air intake temp, but I think that might be built-in already.
Do your temps momentarily show a extreme high and low on the 2 different temps? It might be my cheap BT adapter but one trans gauge will max out at 350* and the other will min out at -140*.
Thanks - what is the dashboard temp gauge reading? Coolant temp?
Typically its Coolant Temp and those gauges aren't very accurate, most are set to have 1/2 as "Normal" but aren't really intended to be more than a "go/no go" gauge really. I believe they may put oil temp on some vehicles, but again its more or less a Skeuomorph as it provides no significantly useful information.
increasedc
