OME 5th Gen. 4Runner data
AlexJet
Fellow 4Runner owners of the 5th Gen. Who installed OME suspension, need your feedback.
Do you have Before and After measurements and pictures of your vehicles? How much actual lift did you gain?
What suspension setup do you run?
- Front (2884, 2885, 2886, 2887)
- Rear (2889, 2895, 2898, 2899)
Did any installed either Front (OME95PF5) or Rear (OME150PR10) Packers?
Stock dimensions:
Limited with 245/60-R20 (31.6")
Front: 34" (driver), 34-3/8" (passenger)
Rear: 36-1/8" (driver), 36-5/8" (passenger)
I have a 2015 TE that came with a spacer lift but this is still good for comparison of the final result. I removed the spacer lift and stock suspension and replaced it with OME:
FR COILS....OME2884
FR SHOCKS...OME90010
REAR COILS...OME2889
REAR SHOCKS...OME60080
Measurements are from ground to wheel well and top of center cap to wheel well.
Before:
Ground........... Center cap
LF 37 5/8".........20 5/8"
RF 37 3/4".........20 3/4"
LR 38 1/4".........21 1/8"
RR 38 3/4..........21 5/8"
After:
LF 39"...............22"
RF39"................22"
LR 40 1/8"..........23"
RR 40 1/4"..........23 1/8"
I did use the spacer I removed to make leveling spacers for the left to right lean. Using a saws-all I cut off 3/8" slice on the front spacer and used it on the left front and cut 3/4" off a rear spacer and used it on the rear left. Did a good job of getting rid of the lean.
It's noticeably lifted.
I don't have specific measurements but I can tell you my relatively stock setup with 2884s in the front sagged pretty quick. If I had to do again I would have opted for 2885. The 2895e rear spring has been great and has little sag after a year or so
Sent from my SM-G920V using Tapatalk
FR COILS....OME2884
Before:
After:
What brand and size spacers did you had? I'm assuming those were poly spacers, like Daystar, as you cut them? We're the front preload or topout?
Looks like you gained ~1.5" with OME over Spacers...
They were Daystar poly's . Topout. Cut real easy with a power saw.
FR COILS....OME2884
Before:
After:
I just looked back at your data and compared to mine.
Front: 39 - 34.25 = 4.75
Rear: 40.25 - 36.25 = 4
That looks allot. Do you still run the OEM tires?
My tires are Toyo Open Country AT 285/70 17.
Laredotx
