OME 906sjust received my ome 906s and Bilstein
heinz58
Junior Member
Just received my ome 906s and Bilstein 5100s from wheelers. No markings on springs as to left or right. Do I assume the taller of the two is driver's side. Sounds stupid I know but just checking
They should have paper tags marked A and B that match instructions. Failing that, common sense will prevail. One is noticeably taller for the drivers side.
Good for asking, many have had to do it twice.
The springs have tags-906 with a part number. Both part numbers are the same. I assumed the taller one was driver's side but I didn't want to do it twice . Thanks for the reply
Quite safe to assume that. I should be able to help ID them, as I put some OME/5100s on all four corners of mine recently, but I only remember there being a labels on the front set. Driver + battery + a (full) fuel tank being on the driver's side = taller spring to compensate.
I think my 906s were 15" on the passenger rear and 15 1/4-1/2" on drivers side rear.
