OME BP-51 Complete Kits
We have a seen recent increase in orders for the
Thank You!
Here is a quick update on availability...
OME BP-51 Complete Kits;
OME4RNR10MKBP51 - In-Stock and Ready to Ship
OME4RNR10MKBP51KD - In-Stock and Ready to Ship
OME4RNR10HKBP51 - In-Stock and Ready to Ship
OME4RNR10HKBP51KD - In-Stock and Ready to Ship
_
It's that time of year again.
Las Vegas has started preparing for the Off-Road Season.
All attention is focused on preparing for the Annual MINT 400
_
We just wanted to share a quick update.
OME BP-51 Complete Kits are In-Stock and Ready to ship - Click Here
All recent orders have shipped out same day.
Order yours today while supplies last.
When ordering online, use Promo Code "T4R" for added savings on most brands.
_
All current orders shipped out today!
ARB had stock delay on Medium Load Kits for KDSS and
Non-KDSS, but everything is good to go now.
_
5th Gen 4Runner KDSS and Non-KDSS Complete Kits are In-Stock and Ready to Ship.
OME BP-51's offer improved Ride and Performance over Stock Struts and Shocks.
The Coilovers up front start with a choice of coils, medium or heavy load, for added
support, as well as, Compression Control for Rebound Dampening. This gives you the
opportunity to dial in you ride-comfort for Daily Driver and Off-Road Use.
The Complete kit comes with either a Medium or Heavy Load coil in the rear. Adding to
your ability for support and compression control.
To review options available - Click Here
_
Love mine but :girl I have a very annoying clunk at low speed
arb wants me record the sound and send it to them
On speed bumps this beast just eats them up road manners have definitely improved
Very adjustable on stock set up gained 2.3 inches on lift
I wish that clunk is resolved soon
Mike
Do locals get a better price? =)
_
Here is a Update on Availability of OME BP-51 Complete Kits;
_
I believe I had seen a light/stock load 1.5 inch lift of the BP-51 somewhere for KDSS. Am I imagining things?
We have not seen an actual "BP-51 Light Load Kit" as of yet.
This may be because there is not a 5th Gen "Light Load" coil for the rear.
Here are the current rear coil options...
Part #2889, Medium Load (200-400lbs)
Part #2898, Heavy Load (440-650lbs)
Part #2899, Heavy Load (880lbs)
It is possible, to create a Light Load BP-51 Complete Kit using FJ Cruiser rear coils;
Part #BP5190002R, Front Right, Coilover
Part #BP5190002L, Front Left, Coilover
Part #BP5160025 (2), Rear Shocks
Part #2895E, 1.5" Rear Coils (FJ Cruiser Light Load)
Part #VM80010028, Front Fit Kit
Part #VM80010, Rear Fit Kit
*for KDSS, Part #VM80010009, Front Fit Kit
The only difference is the rear coil.
_
We want to share a quick Update from ARB/OME.
OME BP-51 Complete Kits are in transit from Australian
and expected to arrive by the end of August.
We have see a recent increase in orders for OME Shocks,
OME Coils and BP-51 Complete Kits.
If you are waiting on availability, now is a great time to
get your order in.
Need help with your build? Let us know how we can help.
Complete List of BP-51 Complete Kits - Click Here
_
** NEW ** OME Upper Control Arms (UCA's) for 5th Gen 4Runner
A Perfect Fit for the OME BP-51 Suspension System.
Old Man Emu Front Upper Control Arms are now available for Toyota
4Runner and a perfect match for OME suspension options.
When installing a new coilovers or struts to an Independent Front Suspension (IFS)
vehicle, the caster and camber can be pushed outside the factory specifications.
IFS vehicles generally have a few degrees of adjustment in their camber
and caster from the factory.
ARB 4x4 Accessories is pleased to announce the addition of the
Toyota 4Runner OME UCA’s that will help bring the alignment cams
back into an acceptable range for both caster and camber.
Features
• Forged Ball Joint Housing
• Forged Eyelets
• Heavy Duty greasable Ball Joint
• OME Ball joint protective cap
• GIIRO bushings, free pivoting, grease free and maintenance free
• Increased camber/caster for 2in lift
• Mount provision for OE ABS wires
• ARB’s Intergrit powder coat finish
• Boxed in pairs with foam inserts
• Fitting instructions included
• OME Branded outer sleeve
• Tested and passed to meet VSB14 requirements
Wheel Alignment is required when installing shocks and UCA’s.
If the vehicle is fitted with aftermarket tires/wheels, fender clearance
should be checked. Additional caster may be required if the tires/wheels
do not clear. Wheel alignment information is included in the fitting instructions.
OME Upper Control Arms will provide an increase between +2.5 and +3.5
degrees of caster and up to 1.5 degrees of negative camber increase
(figures based off an approximate 50mm or 2in lift).
MSRP: $560.00
Online: $543.20
Available August 2020 - Click Here
_
OME BP-51 Complete Kits continue to be a popular choice for 5th Gen 4Runners
Looking to get your hands on a suspension system?
Here is a current update on BP-51's...
OME4RNR10MKBP51 - ETA 11/16
OME4RNR10HKBP51 - ETA 11/16
OME4RNR10MKBP51KD - ETA 11/16
OME4RNR10HKBP51KD - ETA 11/16
The ALL NEW BP-51 Complete Kits with UCA's are still pending release;
Item: 4RBP51MP – NO ETA
Item: 4RBP51HP – NO ETA
Item: 4RBP51MKP – NO ETA
Item: 4RBP51HKP – NO ETA
The New OME UCA flew off the shelves and is now on backorder;
UCA0004 – NO ETA
*ETA's shared for BP-51 Complete Kits are for order placed today.
*Lead time may change due to demand.
_
seltzernator
