OME885 Superflex LR UCA's
playinthewoods
I had been running bilstein 5100's in all 4 corners with FJ springs for a couple of years with the front set to 1.75". This past weekend finally swapped out the FJ springs with 885's with 1/2" spacers front and Superflex rear. Also put in LR UCA's. Mike, (Jester4kicks), who's such an awesome and kind dude, came by and guided me through the entire installation process. It pretty much took the two of us the entire Saturday. Can't thank you enough, Mike! Look forward to you getting your front bumper when I can help and return the huge favor! :)
Got it aligned a couple of days ago. I'm liking the ride! Here are some Before and After measurements and pictures.
Before - from ground to center of wheel well fender line
DF - 36
PF - 36 1/4
DR - 36 1/2
PR - 37
After - from ground to center of wheel well fender line
DF - 38 5/8
PF - 39
DR - 38 5/8
PR - 39
From center of wheel hub to wheel well fender line
DF - 23 1/2
PF - 23 3/4
DR - 23 1/2
PR - 23 5/8
Before - bilstein 5100's set to 1.75" with FJ 4x4 springs
R5_zpsf37e9638.jpeg~original
R6_zpsee21a689.jpeg~original
R1_zps0f0da40b.jpg~original
After
R9_zps2f59b8cb.jpg~original
R10_zpsbdcbe156.jpg~original
R19_zpsc1cbbd03.jpg~original
R11_zps0309a12e.jpg~original
R12_zpsb0b603d8.jpg~original
R14_zps9c8be00f.jpg~original
R15_zpsc3fbd646.jpg~original
Here are the alignment numbers. Casters are high enough so the truck tracks pretty well at high speed and is not skittish. I was a little concerned about the camber and toe numbers, but it drives straight.
R21_zps192b5cb5.jpg~original
Looks good, man. It was a lot of fun... even if it was hotter than the devil's bunghole. Glad to finally see some before and afters!
Philthyphilthy
