Hi,
Have a 2004 Limited with a full ICON 2.5" lift:
• Icon 2.5 Extended Travel Coil-over Shocks
• Icon Tubular UCA’s
• Icon Rear 2” Springs
• Icon Rear VS 2.0 Shocks
• all associated caps, guards etc.
Also have installed:
• SCS Stealth 6 Matte Gunmetal Rims 17x8.5
• BFG AT 285/70r17- 5 tires
Here is my issue,.. I of course had a bit of rub on both sides,.. after all, the tires are a bit bigger than stock
. The rubbing was constrained to the outside of the tires rubbing on the inner, bottom portion of the wheel well, at about 60% lock (if I turned left, the outside of the US Drivers-side tire would rub as it hit fender, never the inside of the tire, and turning right would do the same with the US Passenger-side tire on its' outer edge).
I removed the front mud flaps and the US Drivers side still rubs. The tire appears to be about 1/2-1" further back than the US Passenger side?!
No damage history,.. shop put it on a lift and checked for any damage and zero there. Looks great and pampered (although they are NOT a frame repair shop - and I saw no bends/creases either)
Has anyone seen anything like this before?.. is there a way to adjust this on an IFS vehicle?.. I had it aligned and she tracks straight without issues and all the numbers in factory spec.
As I am back home for a few weeks before I leave the area again to work for our beloved Uncle Sam,.. I'd love to get this resolved ASAP.
Thanks in advance,
Bill
Thanks in advance,
Bill
