borfoo3
sup, I’m alive![]()
Yeah I never messed with it, just sealed up the plugs and never looked back, it runs good and life’s been tooooo busy to do any tinkering lately. :girl:
Doooooooooooooo itttttttttttttt
sup, I’m alive![]()
RIP OP.... We need a volunteer to let his memory live on.
KDSS bypass wiring
Stock wiring
Sample bypass wiring
Maybe this switch
Stock FO2 connectors (if you don't want to cut anything)
I think you could easily tap into it using stock connectors right there at the stabilizer control.i might make this, does anyone know where the ECU is so I can intercept?
Bump to keep this alive
Anyone has updates?
RIP OP.... We need a volunteer to let his memory live on....
Sub’d. I need to look into this. I hate the kdss. Should have paid more to not have it in the pro lol.
Is there even an option to have a trd off road ( premium or not) with out kdss for 2019? My main thing was to have the manual transfer case lever over the auto selector even tho I’m sure I could have just swapped that [emoji2359][emoji24]
In some markets they only sell KDSS, but in general yes KDSS is an option that you paid a lot more for
The transfer case lever doesnt really add much because the front axle disconnect is still electronic, so jot sure why that was the selling point for you.
I love the KDSS though, I think the 4Runner handles like absolute trash without it
So I just want to confirm when you unplug the harness from the kdss system just below the drivers door , it indeed puts your kdss system in the softer setting. So much more enjoyable to drove around town and even on the dirt. And also not just one crossed up sections where your suspension has to articulate. Even when hitting dips when both wheels are compressing. You would think it doesn’t matter but I’m going to bet that in that setting , the kdss shock / link gives a little.
I need to make a switch ASAP.
Next I need to figure out this traction control switch deal.
Bump for this. I’ve personally ridden in Dom’s rig and can confirm the plushness of the limp mode KDSS. Hope the switch gets made soon!
I’ve got it figured out. I’m literally just trying to refine the whole switch setup and having to make the plugs is really the hardest part. But I’m getting there. Thanks man.
