Ordering toytec lift soon, need opinions...
00_4runner
Hey guys I'm continuing my runner purchase spree and I'm buying a full lift kit soon. I'm definitely going toytec coilovers. The question or need for opinions comes from whether or not to buy the 600 or 650lb springs. Im gonna have an ARB bumper installed soon with winch and some lights, I think the 600s are sufficient but again Im not sure. As far as the rear the question is similar. 890s or 891s? I dont carry much in the trunk and after the money Im spending on parts now Im not sure when Ill be able to afford a rear bumper.
So 600lb or 650lb?
AND
890s or 891s?
Thanks in advance all opinions appreciated! :thumb3:
I have the 600lb. coilovers and an ARB bumper without a winch and now sort of wish I went with the 650 lb. coils.
See this thread.
http://www.toyota-4runner.org/3rd-gen-t4rs/95254-toytec-help-please.html
I have mine cranked up to 22.5 inches between the center of the hub and the bottom of my fender. Toytech only recommends 23 inches max for their coilovers.
My driver's side is cranked up quite a bit which of couse makes the ride harsher.
So, if you're going to add the ARB and also a winch down the road get the 650's.
I have the 600's with a pretty heavy tube bumper. I think the setup is fine. If I end up getting a winch, I'll probably switch them out to a more heavy duty coil.
I have the exact lift and I'm pretty sure I have The heavy coils front and rear. It sits pretty flat and rides good even with the new tube bumper and winch. I do have a synthetic cable but still a lot of weight up front. I didn't adjust my front coils at all either. I carry about 100 plus pounds of weight in. The cargo area at any given time too. Make sure and read the sticky about lifts on the main page, you might change your mind on a lift.
2001ATL
