OTRATTW Question
zooroadbaja
I did a quick search, and couldn't find what I was looking for. I want to switch my switches over to the OTRATTW switches. I would need one for the rear locker, center diff, traction control, and the front led bar. I'm not sure what switch configuration I need for what. Can someone help me out.
Also does anyone know where I can get this 3 switch holder? Also I have the configuration below, do I just cut it out to fit the 3 wide switch holder? And does anyone know if the 3 wide will hold 3 OTRATTW switches?
dashswitches.jpg~original
001-5.jpg~original
I'm fairly certain those are the carling rocker switches, you might have better luck searching for what you after using that keyword instead. I am able to buy them locally under another name for a decent price.
The switch that came with my 12volt guy e locker wiring is infact a carling rocker and fit into the single switch hole fairly easily (read minor filing).
The truck shop i used to work at used waytekwire.com alot and we could get those switches and holders through them.
Happy searching!
For the Rear Locker and Center Diff you will need the "SPST ON/OFF switch". There are 2 different options for this switch and you can go with either one based on your personal preference. The only difference is that the switches with two 12V lights have a separate bottom light that can be wired independently to your headlight/ruinning light control switch so they light up when you turn on your running lights/headlights. The switches with just one with 12V light simply lights up when the switch is in the "ON" position.
As far as the Traction Control System, I am assuming you mean a switch that will control the "Andymod". If you do mean the Andymod, then you will need the "SPDT ON/ON" switch. This switch can be used as a SPST OFF/ON, which is exactly what you need to control the Andymod. It is the last switch on this page: OTRATTW.
I chose to go with the switches with two 12V lights. You can see in the pics below what the small light looks like.
IMG_0525.jpg~original
Running Lights/headlights on, switch off:
IMG_0436.jpg~original
Running Lights/headlights on, switch on:
IMG_0441.jpg~original
The 3 switch holder is available here: OTRATTW.
Yep, I have the exact same setup and I just used a Dremel to cut out the space needed to fit the switch holder. Yes, the OTRATTW switches will fit perfectly.
Sorry for the longwinded response but I hope this helps.
That answered all my questions perfectly, thanks a lot. I want to run the same exact setup. How hard is it taping into the running lights?
2001ATL
