Our '87 4R SR5 Honduras Coffee/Missions Rig Build...
HAPPY NEW YEAR 2016!!!
Our New Years resolution... Be in Honduras by Jan. 2017!!!
This will take encouragement, prayer, support, strength and Gods divine intervention.
May you be blessed this new year! -Kent Fam ImageUploadedByTapatalk1451679827.888589.jpg
I am impressed with the way 'Pepe' is coming along! Rear bumper & tire swing out, looks great! Your soft topper makes me really want one of those! I love what you're doing, keep going! Looks great! You have inspired many of us, I'm sure!
Got the snorkel lined so it would be UV protected. Only cost $25!ImageUploadedByTapatalk1453408425.762319.jpg
Yeah it's cold and rainy, plus we are cleaning/prepping/packing for Honduras. So my time gets split up, but I'm determined to be there this year!!
Pictures from today of some of our baby coffea plants we planted let last year. ImageUploadedByTapatalk1453499840.854937.jpg
If this isn't an appropriate post, please feel free to delete mods. Thank you!!
NEW GIVEAWAY!!!
Win coffee for two by following some simple instructions!
What to do:
1. SHARE the post on our Facebook page.
https://facebook.com/AdventureCopan
2. LIKE our Facebook page
3. LIKE that post on our wall.
4. COMMENT "want" in the same post.
Once we reach 510 likes on our page you will be entered to win two coffee mugs and a bag of Honduran coffee! In honor of our neighboring country one of the coffee mugs is from Guatemala and one is from Honduras. We'll even ship it to you for *FREE!
Good luck! -Adventure Copan
*Free shipping applies only to the Continental United States. ImageUploadedByTapatalk1454172232.256358.jpg
Got the topper in and did a test fit. Having the front window replaced Friday, so after that I'll work on remounting the snorkel. ImageUploadedByTapatalk1454538742.830352.jpg
[MENTION=80771]RAD4Runner[/MENTION] do you have any advice? I'm having the front windshield replaced tomorrow.
there is a guy on T4R.org (rad4runner?) that has tons of tips and tricks for the first gen.
He goes into quite a bit of detail on the windshield rubber.
Don't know if you've seen it.
Hi Daniel,
I suggest you take your time doing it right, because might find lots of rust (even if only superficial like I did on mine) because of that chrome trim. I am dealing with it now, and want to approach this methodically because it does rain in Southern California :)
Please see my thoughts on this in my thread
Rust under in the frame rail of that window in the lower corners is the only reason why I ended up repainting my truck!
There were small rust holes on the driver's side, it would leak into the cab from that point, and because I don't drive the truck a lot, sitting outside for a month caused the whole cab to fill up with mold!
Make sure you fix it if you see any rust in those spots, they WILL come back to haunt you over time!
Mine:
I haven't pulled one myself, but I've watched it in person many times. If you aren't worried about the glass breaking (since you have cracked glass, it will most likely crack more when you pull it out), it shouldn't be too hard.
The big problem with rust in there is when the glass guy pulls it out and scratches the paint off in those corners, then just slaps the window back in over the bare metal. Water gets in and it starts rusting.
You'll probably want some cheapo glass suction cups, Harbor freight sells to different types, dual cup with handle, and a single cup with handle. I would think the dual cup would work better, but both do a good job. I use them for removing large acrylic sign panels from backlight sign boxes.
Cutting the seal will be the hardest part, You will need a really stiff wire hangar to poke through the seal and into the cab, with something like a guitar string or other really strong metal wire. You'll use it like a sawing motion all the way around to cut the seal away from the body.
With two people, use the suction cups, pull it away and throw it out. Then you can spend the next few hours cleaning that rail all the way around! I would definitely seal it with some sort of paint or other rust preventative once you're done.
If you see holes, you're gonna want to braze them shut with an oxy-acetaline torch and brazing rod. Check behind for any wires or soundproofing so they don't catch on fire!
If the holes are too big to braze (mine were literally pinholes, super-small and easily brazed shut, but the body guy brazed a metal strip in there too just to make sure it was all good), you're gonna need to form a small strip of metal to repair it.
Call around and see who will pull the window, then come back to reinstall later, might be a few bucks more for the guy to come back a second time to install, but having them do the work and take the glass away would probably be worth the cost!
Thank you! I agree with you. I called the installer and he says when he comes out Tue. he will pull the window and if I feel like he needs to come back to reinstall so I can repair it he will. So Tue. I'll post up and damage and if there is some I'll get it done!! Thank you!!
averyberryman061493
