Outdoor Logic bumper install
Brian Keeler
A good 1/2" drill bit, cutoff wheel, some wrenches and sockets and some electrical connectors is all you need for this project. The lift made it nice!
Glad to see another Happy customer for ODL. It is a nice straightforward install. I wish I had a lift in my garage, not to mention a classic Bronco. Looks good.
I wish Outdoor Logic would offer the bumper without the tubing up top like shrockworks does.
They do offer it without the tubing.
3 options
Flat top- no tubing
Pre runner- single center hoop
Full tubing as pictured in this thread
Thanks guys! BTW if anyone wants the stock bumper it is free for pickup. It is dented and the flares trimmed for tire clearance. Or is someone needs a blinker or parts off it. Hate throwing something away someone may be in need of.....Near Richmond, VA
woot OL bumper looks beastly :D:banana:
Thinking if I should or should not mount my front license plate haha right now its not mounted but you got me thinkin!
nice man. looks tough. great addition. if I could only justify it...
wish I knew someone with a lift in their garage!
I used those slots across the top of the bumper. Used a big washer on the inside to strattle the slot. Had my son use his skinny arm to reach in the hole on top. Started the far nut hand tight then slid over to center to tighten rest of the way then added second bolt with big inside washer. Took all of 2 minutes.
The wheels were on it when purchased. Lost a center cap and when I searched for a new one found out these wheels are discontinued. They were called "Victory Wheels" and were sold with your favorite NASCAR driver center caps or the standard V center cap that was on this one.
http://www.custom-wheels-n-rims.com/nascar/nascar-wheel8.jpg
I like it better without the center caps....
The black powdercoat matches perfect with the black runner paint! ODL exceeded all expectations-love it and recommend it. BTW at first I was thinking of going without the tubes or maybe just the front guard but the way the tubes run are so sexy and make it stand out, not to mention protection! Money well spent and the welds are beautiful!
Since Jimmy was running a sale with the saved money I splurged on the hoops, powdercoat and the lights. I went with the Halogen's Jimmy sells.
Outdoor Logic :: Lights
They are not hooked up yet, just found out I can use the plug off the factory fog lights to run these so it will be an easy hookup and I will be able to unplug when I have to pull the bumper to put a winch on.
